Installation script failure when installing NSO
jeyriku
Level 2
Level 2
Hi Team,
I am facing an issue when trying to install NSO:
sh nso-5.7.1.darwin.x86_64.signed.bin        06:42:11
Unpacking...
Verifying signature...
nso-5.7.1.darwin.x86_64.signed.bin: line 81: python: command not found
nso-5.7.1.darwin.x86_64.signed.bin: line 90: python: command not found
ERROR
ERROR Failed to perform signature verification.
ERROR Verification requires Python version 2.7.4 or later.
ERROR
It looks like my system is not able to point out the correct version of python to be used by the SH script.
Thanks in advance for your help !
Kind Regards,
Jerems
You can create a symbolic link it would be better. If you use another user it will work.
You got this error message because the script was able to find python executable in your PATH.
 Can you mark it as solved ?
5 Replies 5
Nabsch
Can you execute the command  and put the  output .
python --version
You need at least python 2.7.4
Hi @Nabsch,
Thank you so much for commenting my post !
~ ❯ python --version
Python 3.9.12
Just to let you know that i've created an alias :
python=python3
Jerems,
I have executed python --version getting 3.10.4
But still getting same error.
jeyriku
Level 2
Level 2
Thanks again for your help @Nabsch !! Have a great day !
