Interface shutdown test for existence in xml template
RichardD2
I need to execute a block within my xml template if and only if, the interface is shutdown(in the config not live-status).
This test shows the existence of the condition
admin@ncs# show running-config devices device iosxr-r3 config interface Bundle-Ether 18 | display xpath
/devices/device[name='iosxr-r3']/config/cisco-ios-xr:interface/Bundle-Ether[id='18']/description "<< Blah>>"
/devices/device[name='iosxr-r3']/config/cisco-ios-xr:interface/Bundle-Ether[id='18']/mtu 1522
/devices/device[name='iosxr-r3']/config/cisco-ios-xr:interface/Bundle-Ether[id='18']/ipv4/mtu 1500
/devices/device[name='iosxr-r3']/config/cisco-ios-xr:interface/Bundle-Ether[id='18']/ipv6/mtu 1500
/devices/device[name='iosxr-r3']/config/cisco-ios-xr:interface/Bundle-Ether[id='18']/shutdown
/devices/device[name='iosxr-r3']/config/cisco-ios-xr:interface/Bundle-Ether[id='18']/load-interval 30
My XML template (snipped to show relevant piece):
snip>
<?set be_shutdown = {count(../../ncs:devices/ncs:device[name='device_name']/config/cisco-ios-xr:interface/Bundle-Ether[id='be_id']/shutdown)}?>
<snip>
<?if {/be_shutdown > 0}?>
      <interface xmlns="http://tail-f.com/ned/cisco-ios-xr"> ….
Also tried:
 <?set be_shutdown = {string-length(../../ncs:devices/ncs:device[name='device_name']/config/cisco-ios-xr:interface/Bundle-Ether[id='be_id']/shutdown)}?>
<snip>
<?if {/be_shutdown != ''}?>
        <Bundle-Ether tags="delete">
Neither of these work and I suspect it's due to the fact that the template either always returns an empty node or 0
Processing instruction 'set': evaluating expression for variable be_id (from file "migration_cleanup-template.xml", line 8)
Evaluating "/be_id" (from file "migration_cleanup-template.xml", line 8)
Context node: /services/migration_cleanup:migration_cleanup[device_name='iosxr-r3'][be_id='18']
Result:
For /services/migration_cleanup:migration_cleanup[device_name='iosxr-r3'][be_id='18'], it evaluates to "18"
Processing instruction 'set': evaluating expression for variable be_shutdown (from file "migration_cleanup-template.xml", line 9)
Evaluating "string-length(../../ncs:devices/ncs:device[name='device_name']/config/cisco-ios-xr:interface/Bundle-Ether[id='be_id']/shutdown)" (from file "migration_cleanup-template.xml", line 9)
Result: "0"
How can I test for the shutdown condition to be present in the xml (not using python or code here)
thank you,
R
gmuloche
the way you are using your variable looks incorrect:
Have a look here:
https://github.com/NSO-developer/tme-demo/blob/0ea92876c50d825a6bf96cf21b6a19d980794394/packages/tme-demo/templates/data-centre.xml#L32
Probably should be:
<?if {$be_shutdown != ''}?> <interface xmlns="http://tail-f.com/ned/cisco-ios-xr"> <Bundle-Ether tags="delete">
I have tried out the count technique (on some Nexus but should be the same) and it should work I guess
admin@scratch(config)# xpath eval count(/devices/device[name='swn1-bgw-bi0514']/config/interface/Ethernet[name='1/1']/shutdown)
admin@scratch(config)# xpath eval count(/devices/device[name='swn1-bgw-bi0514']/config/interface/Ethernet[name='101/1/1']/shutdown)
However note that in your template the root-node is the service (you can read more about this in the nso development guide on templates)
so you would need to do something like:
<?set-root-node {/}?>
<?set shutdown1 = {count(/devices/device[name='swn1-bgw-bi0514']/config/interface/Ethernet[name='1/1']/shutdown)}?>
<?set shutdown101 = {count(/devices/device[name='swn1-bgw-bi0514']/config/interface/Ethernet[name='101/1/1']/shutdown)} ?>
to get the values - you can also leverage the save-context and switch-context processing instructions if you need to come back to your service context.
gmuloche
Have a look here:
Probably should be:
RichardD2
Hi gmuloche,
Thanks very much for the reply and great explanation - that fixed it!
R
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
