Is it possible to read YANG extension data with Python API
Diddi
Frequent Visitor
Frequent Visitor
I'm writing an NSO Action that will recursively walk a bunch of services and make changes/decisions based on the values found in leafs.
However, I don't want the action to walk NSO internal structures such as the "private" container added by ncs:service-data grouping. This is because there are leafs in there that look exactly like the ones I want to modify, and I don't want to modify NSO internal data for obvious reasons. Taking the "private" container as an example, it's using extension ncs:ncs-service-private and being able to skip walking the container based on this fact would be ideal. Is there a way to see if a container is using this (and other) extensions with the Python API?
Based on some massive guess work and head scratching reading the docs I was hoping the CsNodeInfo.meta_data() method could provide this information, but no matter how I use this I always get "None" as a result.
The action is currently based on maagic and the node._children.get_children() to walk down the tree and get the CsNodeInfo among a few other things but I'm happy to use whatever part of the API that works.
Any ideas?
u.avsec
Maybe printing node name and filtering it could be done but then, what if you have a service "private" nodes you want to use for sure.
I would say, print path as string (xyz._path) and have filters based on xpaths that shouldn't be drilled into.
