Is there any way to do device sync-from periodically?
Raja.Selvaraj
Level 4
Level 4
I want to do a sync-from on a timely basis. Any recommendation or suggestion would be helpful. Thanks.
2 Accepted Solutions
Thanks for your comments. But I want to do a periodic sync for specific interfaces. Is there any North-bound API exposed for partial-sync from in NSO, similar to sync-from (/api/running/devices/_operations/sync-from). Thanks
Yes, the partial-sync-from call is a regular action, and exposed in the same way as sync-from, it was added in 4.4.1. Its arguments are a leaf-list of xpath-expressions. The full definition is available in tailf-ncs-devices.yang.
5 Replies 5
yfherzog
In NSO development guide, have a look under chapter "Scheduler".
Yftach
Does it support in NSO 4.4.2.1 version? I don't see the documentation around this on 4.4.2.1 development guide.
vleijon
The schedule is new in 4.5. But, I also want to warn you against doing periodic sync-from, it is fairly bad for performance and generally not a good design choice in the longer term.
