ned-settings cisco-iso-write-memory-setting cisco-ios-transaction-id-method config-id disappear
haofan
Level 4
Level 4
Hi experts,
In NSO iosNedVersion: 5.x.x, NSO have below two commands, to disable write-memory and using config-id to calculate transaction-id
admin@ncs> devices device ce0 ned-settings cisco-iso-write-memory-setting disabled
admin@ncs> devices device 814f03e2-1e47-3f75-bffa-057032ae6fac ned-settings cisco-ios-transaction-id-method config-id
But in iosNedVersion: 6.0.6, I can not find these two commands.
admin@ncs(config)# devices device e8ba21ae-a0c8-344e-af08-32ec1dc79be8 ned-settings ?
Possible completions:
  cisco-ios               cisco-ios ned-settings
  use-confirmed-commit    Control usage of confirmed commit
  use-private-candidate   Control usage of the private candidate
  use-startup             Control usage of the startup datastore
  use-transaction-id      Control usage of fetching the transaction id
  use-validate            Control usage of validate
Who can tell me what is similar command both cisco-iso-write-memory-setting and cisco-iso-transaction-id-method ?
Thanks.
gschudel
Hi Hao
It looks like you were just at the right place... but didn't read the output ?
Notice in your output of "devices device xxxx ned-settings ?" is says "cisco-ios        cisco-ios ned-settings"...
But you didn't seem to go there...
So i did for you
admin@ncs% set devices device ios0 ?
  ned-settings          - Control which device capabilities NCS uses
  netconf-notifications - NETCONF notifications from the device
admin@ncs% set devices device ios0 ned-settings ?
Description: Control which device capabilities NCS uses
cisco-ios             - cisco-ios ned-settings
  use-confirmed-commit  - Control usage of confirmed commit
(skip...)
admin@ncs% set devices device ios0 ned-settings cisco-ios ?
Description: cisco-ios ned-settings
  api             - Configure API (new API features/changes)
  (skip...)
  read            - Settings used when reading from device
  write           - Settings used when writing to device
admin@ncs% set devices device ios0 ned-settings cisco-ios write ?
Description: Settings used when writing to device
  config-output-max-retries        - Max number of retries (one per second) when sending config command to device
  config-warning                   - Device warning regexp entry list
  device-output-delay              - Delay in milliseconds after each config command output to the device
  inject-answer                    - Inject answer to question from device received when applying config (commit phase)
  inject-command                   - Inject command (before or after) specified config-line upon commit
  memory-method                    - Change method to write config to memory
  memory-setting                   - Configure how and when an applied config is saved to persistent memory on the device
  number-of-lines-to-send-in-chunk - Number of commands lines in a chunk sent by the NED to the device.
  replace-commit                   - Replace (or filter) config when writing to device
admin@ncs%
All good!  (but with a slightly different format)
One other comment - it also helps to "look inside the NED" if you have questions. For example, in searching the YANG modules, you can see that the "ned-settings" are in the yang file "tailf-ned-cisco-ios-meta.yang" ...
However, as you've discovered. the structure of this yang module appears to have changed from 5.x to 6.x
the new structure (obviously) matches what you're seeing at NSO CLI...
hope that helps..
Gregg
Cool, thanks for Gregg detail explanations. It work for me.
cool!
also found this in Cisco IOS NED change file for NED 6.0
Please be advised that Cisco IOS NED 6.0 is now available
for download from the Tail-f delivery server.
(skip)....
Enhancements:
- New major release due to ned-settings API CHANGE.
- API CHANGE:
    Due to NED standardisation, moved the YANG path to all ned-settings
    not residing under cisco-ios container. See README for new paths.
    Upgrade code in UpgradeNedSettings.java updates to new paths in CDB.
   (CISCOIOS-985)
(skip)....
cool, got it. thanks.
