Issue Create Route policy for NCS5500 V7. XR netconf via Python in NSO
gkhaled
is there any one had the problem when try to create anew route policy for the NCS5500 XR netconf via Python in NSO?
i try to put some logic in python till can can create new route policy as like below example :
route-policy EBGP_PE1_IN
  if extcommunity rt matches-any (65535:400400) then
    set extcommunity rt (65102:104104) additive
    set community (1:1) additive
    set local-preference 300
    pass
  elseif extcommunity rt matches-any (65535:400200) then
    set extcommunity rt (65102:102003) additive
    set extcommunity rt (65102:102004) additive
    pass
  endif
  pass
end-policy
but the problem that when try to deploy the package , it seems created on NSO but without devices and no configuration deployed on the device .
so is there any one know why the package does not deploy on the devices ?
Hello ,
Since it’s working .Can you mark it as solved ?
7 Replies 7
Nabsch
Can you put your python code ? You can enable trace on the device that might help you to find the root cause.
here are my python code
def cb_create(self, tctx, root, service, proplist):
self.log.info('Service create(service=', service._path, ')')
self.log.info(service.device)
# starting with empty value
val = ''
# looping the list of extcommunity
#for comm in service.device:
DEVs = []
for DEV in service.device:
DEVs.append(DEV.dev)
self.log.info(DEVs)
for rpl in DEV.route_policies:
for comm in rpl.extcommunity:
self.log.info("{} {} {} ".format(type(service.device),len(service.device),comm))
val += f"""route-policy {rpl.route_policy_name}
if extcommunity rt matches-any ({comm.rt_match_as}:{comm.rt_match_id1}) then
set extcommunity rt ({comm.bgp_rt_set_local_as}:{comm.bgp_rt_set_id1}) additive
set community ({comm.bgp_community_as}:{comm.bgp_community_id}) additive
set local-preference {comm.bgp_local_preference}
pass
elseif extcommunity rt matches-any ({comm.rt_match_as}:{comm.rt_match_id2}) then
set extcommunity rt ({comm.bgp_rt_set_local_as}:{comm.rt_set_id2}) additive
set extcommunity rt ({comm.bgp_rt_set_local_as}:{comm.rt_set_id3}) additive
pass
endif
pass
end-policy\n"""
self.log.info(val)
with ncs.maapi.Maapi() as m:
with ncs.maapi.Session(m, 'admin', 'python'):
with ncs.maapi.single_write_trans('admin', 'python', groups=['ncsadmin']) as t:
root = ncs.maagic.get_root(t)
for dev in DEVs:
self.log.info(dev)
device_list = root.devices.device[dev]
self.log.info("Device to read : " + device_list.name)
RPL = device_list.config.Cisco_IOS_XR_policy_repository_cfg__routing_policy.route_policies.route_policy
RPL_create = RPL.create(rpl.route_policy_name).rpl_route_policy
self.log.info("create new RPL : " + rpl.route_policy_name)
vars = ncs.template.Variables()
vars.add('VAL', val)
template = ncs.template.Template(service)
template.apply('route_policy_config-template', vars)
self.log.info("deploy service ")
Can you reformat your code ?
How i can do that ?
Nabsch
You have  to click on insert code
Concerning your code , you made some mistake. You create the RPL but you in a transaction that you had never apply ( commit) so the RPL is not created. If you try to add t.apply() it will fails because you are inside cb_create so you already acquire cdb lock.
I suggest you to create your RPL with a template and you apply your template inside your loop so you can create all the RPL that you want instead of doing
    for dev in DEVs:
    self.log.info(dev)
It would be something like this
for dev in DEVs:
    self.log.info(dev)
    vars.add("DEVICE",dev)
    vars.add("RPL",rpl.route_policy_name)
Hello
it is worked fine now after that change , many thanks
Hello ,
