Leafref from service to device NED config using CDM and NSO 5.3.1.1
JimBoucher
Hi, I am using 5.2.0.3 and have not been able to leafref from a service into a NED config as shown above.  I understood that there was a known limitation in NSO 5 due to CDM. I am working on a port to NSO 5.3.1.1 and saw this in changes:
  • ncs: In CDM, service YANG models could not have references into device
    YANG models.
(ENG-21618)
I am trying to do something like:
https://community.cisco.com/t5/nso-developer-hub-discussions/yang-reference-to-device-platform/m-p/3993230/highlight/false#M4578
I have added a fragment similar to:
https://community.cisco.com/t5/nso-developer-hub-discussions/leafref-firewall-interface-in-service-template/m-p/4051957
I have been trying to replicate the above but I don't seem to be having any luck. I keep getting:
yang/slf-loadbalancers.yang:221: error: the node 'interface' from module 'tailf-ned-cisco-ios' (in node 'config' from 'tailf-ncs') is not found
The code is quite similar. The code is:
type leafref {
path "/ncs:devices/ncs:device[ncs:name=current()/../name]/ncs:config/ios:interface/ios:Loopback/ios:name";
Can you do me a favor and confirm whether ENG-21618 does what I was hoping it would or if I'm doing something obvious, I'd really appreciate a pointer.  The PDF for CDM Migration for NSO 5.3.1.1 does not have an example of this.
Thanks in  Advance,
Jim
JimBoucher
I tracked this down to a Makefile issue:
This fragment was based on the template in the Makefile:
YANGPATH += ../../f5-bigip-gen-3.9/src/ncsc-out/modules/yang \
../../f5-bigip-gen-3.9/src/yang
yang/loadbalancers.yang:185: error: the node 'ltm' from module 'tailf-ned-f5-bigip' (in node 'config' from 'tailf-ncs') is not found
make[1]: *** [../load-dir/slf-loadbalancers.fxs] Error 1
This pattern matched the template:
## Uncomment and patch the line below if you have a dependency to a NED
## or to other YANG files
# YANGPATH += ../../<ned-name>/src/ncsc-out/modules/yang \
# ../../<pkt-name>/src/yang
When I cut off the last part (as I saw in the above Discussion links) it worked fine.
Thanks for the great Knowledge Base. :-)
JimBoucher
