leafref not displaying in NSO 4.5 webui when used as a list key
ryan-hitch
Level 4
Level 4
I am trying to get the NSO 4.5 webui to display a drop-down list of GigabitEthernet interface names on a Cisco 3560E IOS switch using the simple model listed below. The new NSO 4.5 webui displays a drop-down of available interfaces if I do not use the switch-interface-id as a key, however just displays a blank drop-down list in the popup if switch-interface-id is used as a key. Is there a way to correct this behavior? It is a much more intuitive webui for our end users if we are able to use the "switch-name switch-interface-id" key. Thanks in advance.
list switch {
  key "switch-name switch-interface-id";
  leaf switch-name {
    type leafref {
      path "/ncs:services/ncs:device/ncs:name";
  leaf switch-interface-id {
    type leafref {
      path "deref(../switch-name)/../ncs:config/ios:interface/ios:GigabitEthernet/ios:name";
Display using "name switch-interface-id" key
Display using only "name" type string as a key requires the user to input a unique key when being able to use the "name interface-type-id" would be much more intuitive.
jcederqu
Ryan. Thank you for pointing this problem out. It occurs due to the internal dependency of the key values.  We are working on a solution and hope to have it ready before the next release later this year..
/Jakob
Jan Lindblad
jcederqu, did you see this too?
jcederqu
/Jakob
