Limiting "possible completions" when using the question mark
dapryor
Could anyone tell me the best way to limit the possible completions when creating a service to just when leafs are available in my YANG model?
I only want to expose bgp_info, interface, and vrf_info when in the configuration mode.
You can limit access by aaa, another option is to customize using the clispec mechanism (man clispec), unfortunately I know no simple way of doing exactly what you want.
vleijon
Can you elaborate on what you mean? Completion is limited to things that are available.
Is it that you'd prefer not to show the actions?
Hey thanks for the response.  I want to exclude the completions that are not explicitly created by my yang model.  I would prefer to not show completions such as re-deploy when configuring the service. I would even be fine with separating the options that my model added from the completions built-in such as how commit, describe, exit, and help appear in this screenshot:
Thanks for the reply.  I will look into both.
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
