load operational data to netsim device
sm000x
Level 5
Level 5
Hi, All:
I want to create a netsim device with operational data.
After I create the simualted network:
ncs-netsim create-network <pakage> 3 upf
In netsim/upf/upf0, I see the start.sh has the following:
test -f cdb/O.cdb
first_time=$?
env sname=${NAME} ${CONFD} -c confd.conf ${CONFD_FLAGS} \
--addloadpath ${CONFD_DIR}/etc/confd
ret=$?
if [ ! $first_time = 0 ]; then
true;
## If there is anything we want to do after the
## first initial start, this is the place. An example could be
## to load CDB operational data from xml files
fi
I want to load the operational data: cfgmgr_init.xml
<config xmlns="http://tail-f.com/ns/config/1.0">
<config-schema xmlns="http://affirmednetworks.com/ns/yang/cna-cfgmgr">
<config-schema-list>
<service-type>bgpmgr</service-type>
<version>1.1.83</version>
</config-schema-list>
</config-schema>
</config>
to the netsim device: upf0
I add cfgmgr_init.xml in start.sh:
true;
cfgmgr_init.xml
fi
when I start upf0, I got the following error:
[root@mtznjv1cnro03 packages]# ncs-netsim start upf0
./start.sh: line 35: cfgmgr_init.xml: command not found
DEVICE upf0 OK STARTED
The cfgmgr_init.xml is not loaded.
Does anyone know how to load the operational data to the netsim device?
Thank you
sm000x
Jesus Illescas
Taking a look at the `nso-examples` collection, the `develop-service` on `getting-started` shows how to add oper data to a netsim device.
In the case of the example, this is how they do it
# So for example here we can load operational data
# Test, and only do this the first time
if [ $ret = 0 -a ! $first_time = 0 ]; then
    ${CONFD_DIR}/bin/confd_load -l -m -O ${PACKAGE_NETSIM_DIR}/oper/${NAME}.xml
fi
They are using `confd_load` to load the oper configuration. I would assume that `PACKAGE_NETSIM_DIR` uses an absolute path.
Take a look at the full example https://github.com/NSO-developer/nso-examples/blob/main/getting-started/develop-service/init/router.in/netsim/start.sh#L33C44-L33C62
To keep a record here, this is the full start.sh on the example
# We may optionally have start.sh file in the netsim directory
# It will be transformed and sourced with a set of environment
# variables.
# If we need to start additional C programs we can do that here
# Also if we need to load additional XML/CLI files etc we
# can do that here.
# This script will have access to the following environment variables
# CONFD_IPC_PORT    - which port is this ConfD instance listening to for IPC
# NETCONF_SSH_PORT  - which port is this ConfD instance listening to for netconf
# NETCONF_TCP_PORT
# CLI_SSH_PORT      - which port is this ConfD instance listening to for CLI/ssh
# SNMP_PORT         - which port is this ConfD instance listening to for snmp
# NAME              - what is the name of this ConfD instance
# CONFD             - path to the confd executable
# CONFD_DIR         - path to the ConfD installation
# PACKAGE_NETSIM_DIR - path to the netsim directory in the package which
#                      was used to produce this netsim network
test -f  cdb/O.cdb
first_time=$?
ret=$?
fi
exit $ret
Jesus Illescas
fi
# variables.
# can do that here.
# NETCONF_TCP_PORT
test -f  cdb/O.cdb
first_time=$?
ret=$?
fi
exit $ret
Hi Jesus:
Thank you so much for the help. It works.
Thank you
sm000x
