mismatch while entering a command to device vs device template
erdemk
Dear Community members,
I need some help.
While creating a Device Template,  i cannot enter some CLI command into device template, although i can execute them on the Device ( either directly on device CLI or via NSO, it is same ).
I appreciate any guidance on the reason for this and guidance on how to run a Compliance report for those commands as i cannot enter them into the template.
nso ver : 5.3.0.1
ned : cisco-ios-cli-6.43
Definition of the issue :
CASE 1 : ntp server
i can execute command
ntp server 195.33.242.133
on the device, but not on the Device Template
CSE 2 : logging
logging 10.210.162.238
on the device, but not on the Device template..
Below are command execution output for like "logging ? " or "ntp server ? " and my notes and YANG portion for these commands out of IOS NED for both cases :
CASE 1 : ntp server
When i try to execute command on Device
admin@ncs(config-config)# ntp server ?
Possible completions:
     <IP address>        <--- there is IP address field here
     <string, min: 1 chars, max: 253 chars>
     <Hostname, A.B.C.D or X:X:X:X::X> Address of peer
     ip Use IP for DNS resolution
     ipv6 Use IPv6 for DNS resolution
     vrf VPN Routing/Forwarding Information
When i try to execute command on Template :
ip ipv6 peer-list vrf        <--- there is peer-list field here, in which there is IP address
IOS YANG  for ntp server :
    // ntp server *
    container server {
      tailf:info "Configure NTP server";
      uses ntp-peer-grouping;
      // ntp server ip *
      container ip {
        tailf:info "Use IP for DNS resolution";
        tailf:cli-compact-syntax;
      // ntp server ipv6 *
      container ipv6 {
        tailf:info "Use IPv6 for DNS resolution";
      // ntp server vrf *
      list vrf {
        tailf:info "VPN Routing/Forwarding Information";
        tailf:cli-suppress-mode;
        tailf:cli-delete-when-empty;
        tailf:cli-reset-container;
        tailf:cli-incomplete-command;
        key name;
        leaf name {
          tailf:cli-diff-dependency "../../../../ip/vrf";
          tailf:cli-diff-dependency "../../../../vrf/definition";
          type string {
            tailf:info "WORD;;VPN Routing/Forwarding instance name";
  grouping ntp-peer-grouping {
    list peer-list {
      tailf:cli-drop-node-name;
      key name;
      leaf name {
        tailf:cli-disallow-value "vrf";
        type inet:host {
          tailf:info "Hostname, A.B.C.D or X:X:X:X::X;;Address of peer";
      leaf burst {
        tailf:info "Send a burst when peer is reachable (Default)";
        type empty;
      leaf iburst {
        tailf:info "Send a burst when peer is unreachable (Default)";
        type empty;
      leaf key {
        tailf:info "Configure peer authentication key";
        type uint32 {
          tailf:info "<1-4294967295>;;Peer key number";
          range "1..4294967295";
      leaf maxpoll {
        tailf:info "Maximum poll interval";
        type uint8 {
          tailf:info "<4-17>;;Poll value in Log2";
          range "4..17";
      leaf minpoll {
        tailf:info "Minimum poll interval";
        type uint8 {
          range "4..17";
      leaf normal-sync {
        tailf:info "Disable rapid sync at startup";
        type empty;
      leaf prefer {
        tailf:info "Prefer this peer when possible";
        type empty;
      container source {
        tailf:info "Interface for source address";
        tailf:cli-flatten-container;
        uses interface-name-grouping;
      leaf version {
        tailf:info "Configure NTP version";
        type uint8 {
          tailf:info "<1-4>;;NTP version number";
CASE 2: logging
When i try to execute command on Device :
admin@ncs(config-config)# logging ?
  <IP address>
  <Hostname or A.B.C.D>   IP address of the logging host           <-------------  there is hostname for Template, see blow
  alarm                   Configure syslog for alarms
  buffered                Set buffered logging parameters
  cmts                    CMTS config commands
  console                 Set console logging parameters
  discriminator           Create or modify a message discriminator
  esm                     Set ESM filter restrictions
  event                   Global interface events
  exception               Limit size of exception flush output
  facility                Facility parameter for syslog messages
  history                 Configure syslog history table
  host                    Set syslog server IP address and parameters
  ip                      IP configuration
  linecard                specify logging parameters for a linecard messages
  message-counter         Configure log message to include certain counter value
  monitor                 Set terminal line (monitor) logging parameters
  origin-id               Add origin ID to syslog messages
  persistent              Set persistent logging parameters
  queue-limit             Set logger message queue size
  rate-limit              Set messages per second limit
  reload                  Set reload logging level
  snmp-authfail
  snmp-trap               Set syslog level for sending snmp trap
  source-interface        Specify interface for source address in logging
                          transactions
  trap                    Set syslog server logging level
  alarm             buffered       cmts
  console           discriminator  esm
  event             exception      facility
  history           host           hostname                    <-------------  there is no as such hostname for Device CLI, see above
  ip                linecard       message-counter
  monitor           origin-id      persistent
  queue-limit       rate-limit     rate-limit-conf
  reload            snmp-authfail  snmp-trap
  source-interface  trap
IOS YANG for logging :   ( is very long, hence i only included the hostname portion , which -i believe- for "logging <IP Address>"
  container logging {
    tailf:info "Modify message logging facilities";
    // logging *
    list hostname {
      tailf:info "Hostname or A.B.C.D;;IP address of the logging host";
      key host;
      leaf host {
        tailf:cli-disallow-value "esm|alarm|buffered|facility"+
          "|history|rate-limit|source-interface|host|console";
        tailf:cli-full-command;
        type inet:host {
RichardD2
The NTP commands in your template should look like:
<config>
       <ntp xmlns="http://tail-f.com/ned/cisco-ios-xr">
        <server>
          <server-list>
            <name>1.2.3.4</name>
          </server-list>
        </server>
        <source>
          <Loopback>0</Loopback>
        </source>
      </ntp>
      </config>
Similarly, your logging configuration in the template should look like
<config>
        <logging xmlns="http://tail-f.com/ned/cisco-ios-xr">
          <trap>debugging</trap>
          <monitor>debugging</monitor>
          <buffered>
            <type>informational</type>
          </buffered>
          <host>
            <address>1.2.3.4</address>
            <vrf>default</vrf>
            <severity>info</severity>
            <port>default</port>
          </host>
        </logging>
      </config>
One thing that helps figure these types of things out is to go to a device that has the configuration you want and issue command like:
show running-configuration | display xml
regards
Richard
RichardD2
<config>
        <server>
          <server-list>
          </server-list>
        </server>
        <source>
        </source>
      </ntp>
      </config>
<config>
          <buffered>
          </buffered>
          <host>
            <vrf>default</vrf>
          </host>
        </logging>
      </config>
regards
Richard
erdemk
Dear RichardD2,
very good. now, i am able to synchronize template and device cli. show run | display xml on device made the trick.
many thanks.
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
