NACM configuration for accessing devices in device-group
Hi, Team!
I`m looking for a way to configure NACM permissions for reading configuration of devices in device-group 'group1' to users in user group 'USER-GROUP'.
device-group group1  has config
set devices device-group group1 device-name [ios1 ios2 ios3]
I can easily give access to configuration of all devices, configuration of a single device or configuration group group1 itself
/ncs:devices/ncs:device
/ncs:devices/ncs:device[name='vXR']
/ncs:devices/ncs:device-group[name='group1']
But how should xpath look like if we want to give access to devices in device-group?
It probably should be something like that
/ncs:devices/ncs:device[name=/ncs:devices/ncs:device-group[name='group1']/device-name] (one xpath include another)
Rule config is
set nacm rule-list 1 group [ USER-GROUP ]
set nacm rule-list 1 rule full-deny path /nacm:nacm
set nacm rule-list 1 rule full-deny action deny
set nacm rule-list 1 rule device-config-verification path /ncs:devices/ncs:device[name='vXR']
set nacm rule-list 1 rule device-config-verification access-operations read
set nacm rule-list 1 rule device-config-verification action permit
set nacm rule-list 1 rule device-config-verification context *
set nacm rule-list 1 cmdrule show-permit context cli
set nacm rule-list 1 cmdrule show-permit command show
set nacm rule-list 1 cmdrule show-permit access-operations read,exec
set nacm rule-list 1 cmdrule show-permit action permit
it would be great if someone share correct xpath string for my scenario
Thnks
snovello
the NACM definition (rfc8341) does not give you an unrestricted Xpath for that path leaf. Here is the datatype definition from that RFC
     typedef node-instance-identifier {
       type yang:xpath1.0;
       description
         "Path expression used to represent a special
          data node, action, or notification instance-identifier
          string.
          A node-instance-identifier value is an
          unrestricted YANG instance-identifier expression.
          All the same rules as an instance-identifier apply,
          except that predicates for keys are optional.  If a key
          predicate is missing, then the node-instance-identifier
          represents all possible server instances for that key.
          This XML Path Language (XPath) expression is evaluated in the
          following context:
             o  The set of namespace declarations are those in scope on
                the leaf element where this type is used.
             o  The set of variable bindings contains one variable,
                'USER', which contains the name of the user of the
                current session.
             o  The function library is the core function library, but
                note that due to the syntax restrictions of an
                instance-identifier, no functions are allowed.
             o  The context node is the root node in the data tree.
          The accessible tree includes actions and notifications tied
          to data nodes.";
 It mentions that the xpath should be an instance identifier expression, this is an xpath where any predicate is only of the form [keyleaf='value'], so that it exactly identifies a specific location in your model. The one difference is you can omit predicates to reference all elements in a list. More detail from the Yang RFC 7950 on the identityref datatype can be found here https://datatracker.ietf.org/doc/html/rfc7950#section-9.13
Given  those restrictions you cannot do what you are trying to do in a single rule. Since you are trying to give access to an arbitrary set of devices, you will need a rule per device in the group.
You can use NSO services to generate NACM rules, so you could have a service with a leaf-list of type leafref, referring to device names, and use that service to generate the NACM rules in its template.
If its important to you to use the device group definitions, you could have the device-group name in your service only, but then I would also have a kicker that would also be created in the service template. This would cause the service to be re-deployed whenever the group is changed. That would ensure that on any group change, the NACM rules are updated even though the group definition is not located under your service within the model tree.
