ncs netsim create network
Hello everyone!
I would like to ask about emulating Cisco cisco-ios routers in NSO, I have used the command ncs-netsim Create-network but it showed an error as you can see in the photo.
I sourced the NCSRC in the ex2 dir but still, could you please help me out?
RichardD2
Level 4
Level 4
I notice no trailing / at the end of your NED path. The workflow I typically follow is: (your version number will be different)
source nso-5.4.1/ncsrc
cd ncs-run
 ncs-netsim create-network ~/nso_5.4.1/ncs-run/packages/cisco-iosxr-cli-7.30/ 3 router
 ncs-netsim start
 ncs-netsim is-alive
 ncs-setup --netsim-dir ./netsim --dest
Then run ncs
You don't want to start ncs before the netsim's are created, started and running.
8 Replies 8
u.avsec
Hey,
Seems like you are missing some Linux prerequisite packages. 'make' is missing at least. While you are at it see if 'ant' is also installed.
thanks a lot for your reply, I have installed it but, unfortunately, when i did the command again it says:
abduljwad@u20-netconf:~/ex2$ ncs-netsim create-network packages/neds/cisco-ios-cli-3.0 3 c
/bin/sh: 1: cannot open /home/abduljwad/ex2/netsim/confd/var/confd/cdb/aaa_init.xml: No such file
make: *** [Makefile:41: install] Error 2
*** Failed to install
Try ncs-netsim --help or man ncs-netsim to get usage text
It seems like you are missing install NSO dir or files in that dir.
If you ride that path /home/abduljwad/ex2/netsim/confd/var/confd/cdb/ what do you see? You should see aaa_init.xml with these contents:
<config xmlns="http://tail-f.com/ns/config/1.0">
  <aaa xmlns="http://tail-f.com/ns/aaa/1.1">
    <authentication>
      <users>
        <user>
          <name>admin</name>
          <uid>9001</uid>
          <gid>100</gid>
          <password>$0$admin</password>
          <ssh_keydir>/var/confd/homes/admin/.ssh</ssh_keydir>
          <homedir>/var/confd/homes/admin</homedir>
        </user>
        <user>
          <name>oper</name>
          <uid>9001</uid>
          <gid>100</gid>
          <password>$0$oper</password>
          <ssh_keydir>/var/confd/homes/oper/.ssh</ssh_keydir>
          <homedir>/var/confd/homes/oper</homedir>
        </user>
        <user>
          <name>public</name>
          <uid>9001</uid>
          <gid>100</gid>
          <password>$0$public</password>
          <ssh_keydir>/var/confd/homes/public/.ssh</ssh_keydir>
          <homedir>/var/confd/homes/public</homedir>
        </user>
        <user>
          <name>private</name>
          <uid>9001</uid>
          <gid>100</gid>
          <password>$0$private</password>
          <ssh_keydir>/var/confd/homes/private/.ssh</ssh_keydir>
          <homedir>/var/confd/homes/private</homedir>
        </user>
      </users>
    </authentication>
    <ios>
      <level>
        <nr>0</nr>
        <prompt>\h> </prompt>
      </level>
      <level>
        <nr>15</nr>
        <prompt>\h# </prompt>
      </level>
      <privilege>
        <mode>exec</mode>
        <level>
          <nr>0</nr>
          <command>
            <name>exit</name>
          </command>
          <command>
            <name>action</name>
          </command>
          <command>
            <name>help</name>
          </command>
          <command>
            <name>autowizard</name>
          </command>
          <command>
            <name>enable</name>
          </command>
          <command>
            <name>startup</name>
          </command>
        </level>
        <level>
          <nr>15</nr>
          <command>
            <name>configure</name>
          </command>
        </level>
      </privilege>
    </ios>
  </aaa>
  <nacm xmlns="urn:ietf:params:xml:ns:yang:ietf-netconf-acm">
    <write-default>permit</write-default>
    <groups>
      <group>
        <name>admin</name>
        <user-name>admin</user-name>
        <user-name>private</user-name>
      </group>
      <group>
        <name>oper</name>
        <user-name>oper</user-name>
        <user-name>public</user-name>
      </group>
    </groups>
    <rule-list>
      <name>admin</name>
      <group>admin</group>
      <rule>
        <name>any-access</name>
        <action>permit</action>
      </rule>
    </rule-list>
    <rule-list>
      <name>any-group</name>
      <group>*</group>
      <rule>
        <name>tailf-aaa-authentication</name>
        <module-name>tailf-aaa</module-name>
        <path>/aaa/authentication/users/user[name='$USER']</path>
        <access-operations>read update</access-operations>
      </rule>
      <rule>
        <name>tailf-aaa-user</name>
        <path>/user[name='$USER']</path>
        <access-operations>create read update delete</access-operations>
      </rule>
      <rule>
        <name>tailf-webui-user</name>
        <module-name>tailf-webui</module-name>
        <path>/webui/data-stores/user-profile[username='$USER']</path>
      </rule>
    </rule-list>
  </nacm>
</config>
It is default config for admin/admin access to netsim devices.
RichardD2
Level 4
Level 4
In addition to ANT as someone has mentioned, I would make sure you have:
- a JAVA JDK-8.0 or higher
- Python 3.5 or higher
- xsltproc
- make
You mentioned sourcing ncsrc, but have you also run
ncs-setup --dest ~/NSO-DIR/ncs-run
Thanks a bunch, i already have them and i run the ncs
RichardD2
Level 4
Level 4
cd ncs-run
 ncs-netsim start
 ncs-netsim is-alive
Then run ncs
Trailing / doesn't influence creation of devices
root@1601121d3788:~/cfs# ncs-netsim create-network /var/opt/ncs/packages/cisco-ios 3 router
DEVICE router0 CREATED
DEVICE router1 CREATED
DEVICE router2 CREATED
Also, netsim is separate to NSO, doesn't matter when it is spun up, it can be done while NSO is up and running or when NSO is not set up yet.
The only thing needed is NSO install dir (unless netsim is hacked into being standalone) and NEDs
RichardD2
Level 4
Level 4
You are correct that netsim and nso are two different processes. However, if you start ncs and don't start the netsims, you won't be able to connect to anything.
ncs@nso-devel:~/ncs-run$ ncs
ncs@nso-devel:~/ncs-run$ ncs_cli -Cu admin
admin connected from 127.0.0.1 using console on nso
admin@ncs# show devices br
NAME ADDRESS DESCRIPTION NED ID
iosxr-r0 127.0.0.1 - cisco-iosxr-cli-7.38
iosxr-r1 127.0.0.1 - cisco-iosxr-cli-7.38
iosxr-r2 127.0.0.1 - cisco-iosxr-cli-7.38
iosxr-r3 127.0.0.1 - cisco-iosxr-cli-7.38
ncs@nso-devel:~/ncs-run$ ncs-netsim is-alive
DEVICE iosxr-r0 FAIL
DEVICE iosxr-r1 FAIL
DEVICE iosxr-r2 FAIL
DEVICE iosxr-r3 FAIL
