YANG
Hello guys,
I am trying to implement the :
First create a package called 'host' from the YANG file we have
$ ncs-make-package --netconf-ned . host
We now need to build the YANG file in the package
$ ( cd host/src && make )
but i got this error :
ncs-make-package: error: failed to copy YANG file(s)
Try ncs-make-package --help to get usage text
Could anyone help, please?
u.avsec
You have to pre-provide the yang model when making the ned.
It looks like you just ran the
which searches the current dir for yang files, can't find any and then complain.
You should visit NSO install dir and find 'doc' dir in which a pdf guide called nso_developement is. Most of the stuff is explained there.
Also, if you want to build netconf neds directly from netconf devices this might be an interesting thing to look into:
https://github.com/NSO-developer/pioneer
u.avsec
crench92
Depending on the NSO version, you can also use the netconf-ned-builder
https://developer.cisco.com/docs/nso/guides/#!nso-5-6-ned-development-netconf-ned-builder/netconf-ned-builder
