NCS Noob Help
timed_out
Hi Guys,
I installed NSO (nso-4.7.darwin.x86_64) on OSX today but I cant seem to create a network, I have some output below, would be great if anyone can point me in the right direction:
Note I have installed ant and java 1.8 (not sure if it was necessary or not at this stage, but they installed successfully).
# Source ncsrc
> $ source ~/nso-4.7/ncsrc
# Try to create network as per README
> $ sudo ncs-netsim create-network ~/nso-4.7/packages/neds/cisco-ios 3 c
Password:
*** A netsim network already exists in directory netsim
*** Please use 'ncs-netsim delete-network' to remove it before
*** creating a new network, or 'ncs-netsim add-to-network' to
*** add devices to the existing network.
Try ncs-netsim --help or man ncs-netsim to get usage text
# Deleted the existing network from my previous attemtp
> $ sudo ncs-netsim delete-network
/Users/timedout/nso-4.7/bin/ncs-netsim: line 1196: ./stop.sh: No such file or directory
DEVICE c0 already STOPPED
# Tried again
> $ sudo ncs-netsim create-network ~/nso-4.7/packages/neds/cisco-ios 3 d
Makefile:2: /src/ncs/build/include.netsim.mk: No such file or directory
make: *** No rule to make target `/src/ncs/build/include.netsim.mk'. Stop.
*** Failed to install
# I saw this in other instructions (not in the README). Didnt work either
> $ sudo ncs-setup --dest ~/nso-4.7
cp: /etc/ncs/ncs.conf: No such file or directory
Using netsim dir /Users/nico/netsim
sed: confd.conf: No such file or directory
Help! :)
2 Accepted Solutions
gschudel
hi !
it's unclear if you made a "running directory" for NSO?
generally there are two steps to play with NSO.
a) install the product (looks like you did this - "local install" hopefully) e.g. something like:
    sh nso-4.7.3.darwin.x86_64.installer.bin nso-473
and then (as you show)  "source nso-473/ncsrc"
check this worked if you want "echo $NCS_DIR"
b) and then you need a running dir... examples mostly use "ncs-run" but you can call it anything you want. e.g.
   mkdir ncs-run
   cd ncs-run
   ncs-setup --dest .
(note the "dot" at the end...)
In order to create netsims, you'll need a NED in the packages directory (in this ncs-run dir), so my suggestion is
to copy the one in the distro (where you installed NSO) into this packages dir...
  cd packages
  cp $NCS_DIR/packages/neds/cisco-ios .
Now... you can make a netsim network (with this type of device)
  ncs-netsim create-network ./packages/cisco-ios 3 c
this says create three netsims of ios type with name "c0" "c1" "c2"
you can start them with (simply)  "ncs-netsim start"
to log into a netsim do "ncs-netsim cli-c c0" for example
starting nso is just "ncs"
onboarding the netsims into NSO -- see the docs
(there is another command called "ncs-netsim ncs-xml-init > mydevs.xml" (where mydevs.xml is any name you like
and then "load merge" this file (and commit) from NSO to onboard directly (of course other ways exist too :)
hope this helps.
   mkdir ncs-run
   cd ncs-run
   ncs-setup --dest .
Thanks Gschudel, excellent instructions, I have been missing out running 'ncs-setup --dest .'
But when I try I get the below error:
timedout@my-IMAC ~/nso-4.7/ncs-run [15:02:07]
> $ sudo ncs-setup --dest .
Using netsim dir /Users/timedout/netsim
This is my java version: > $ java -version
openjdk version "11.0.2" 2019-01-15
OpenJDK Runtime Environment 18.9 (build 11.0.2+9)
OpenJDK 64-Bit Server VM 18.9 (build 11.0.2+9, mixed mode)
7 Replies 7
gschudel
hi !
   mkdir ncs-run
   cd ncs-run
   ncs-setup --dest .
  cd packages
hope this helps.
   mkdir ncs-run
   cd ncs-run
   ncs-setup --dest .
You've missed a step somewhere...
check "echo $NCS_DIR" -- what does it say?
did you do a "local install" or "system install" of NSO?
did you make a "running directory" ?
I think I did a local install, I installed it twice and not 100% sure. I will delete the nso-4.7 directory and reinstall, then try again.
But yes I do have an ncd-run directory and $NCS_DIR output is below, I'll post my results when I try again, making sure i so local install.  Thanks again.
timedout@IMAC ~/nso-4.7/ncs-run
> $ pwd
/Users/timedout/nso-4.7/ncs-run
> $ echo $NCS_DIR
Sorry for the delay, i used --local-install this time and I seem to be going well.  I have created the ncs-run folder and copied the sim, but now I get this error:
> $ ncs-netsim create-network ./packages/cisco-ios 3 c
*** The NED package called <./packages/cisco-ios> doesn't have a
*** netsim directory. ncs-netsim cannot emulate
*** devices that do not have a netsim directory.
*** Maybe its a generic NED ?
> $ pwd
/Users/nico/nso-4.7/ncs-run
> $ ls -la
total 32
drwxr-xr-x 10 nico staff 340 23 Mar 17:31 .
drwxr-xr-x 24 nico staff 816 23 Mar 17:27 ..
-rw-r--r-- 1 nico staff 585 23 Mar 17:27 README.ncs
drwxr-xr-x 12 nico staff 408 23 Mar 17:31 cisco-ios
drwxr-xr-x 2 nico staff 68 23 Mar 17:27 logs
drwxr-xr-x 2 nico staff 68 23 Mar 17:27 ncs-cdb
-rw-r--r-- 1 nico staff 9357 23 Mar 17:27 ncs.conf
drwxr-xr-x 2 nico staff 68 23 Mar 17:27 packages
drwxr-xr-x 4 nico staff 136 23 Mar 17:27 scripts
drwxr-xr-x 2 nico staff 68 23 Mar 17:27 state> $
> $ echo $NCS_DIR
/Users/nico/nso-4.7
> $ ncs
> $ ncs --status | grep status
status: started
Thanks for you're help gschudel
Using the below command worked!  I know its my syntax that caused the issues..
Thanks for your help!
> $ ncs-netsim create-network $NCS_DIR/packages/neds/cisco-ios 3 c [±master
DEVICE c0 CREATED
DEVICE c1 CREATED
DEVICE c2 CREATED
vleijon
Missed the existing reply. Ignore this.
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
