NCS Python question: Modifying a leaf value
previousqna
Level 8
Level 8
Hi All,
I’m trying to get a clear idea what is needed to modify a leaf value in a service model.
Just running at an interactive prompt I’m trying the following:
import ncs
mr=ncs.maapi.Maapi()
mw=ncs.maapi.Maapi()
sr=ncs.maapi.Session(mr,'admin','admin')
sw=ncs.maapi.Session(mw,'admin','admin')
tw=mw.start_write_trans()
tr=mr.start_read_trans()
rroot=ncs.maagic.get_root(tr)
wroot=ncs.maagic.get_root(tw)
It’s likely not necessary, but I have a read(tr) and a write transaction(tw) setup.
>>> rroot.services.autovnfpair__autovnfpair["Auto1"]["mytest"]
'firstValue'
>>> wroot.services.autovnfpair__autovnfpair["Auto1"]["mytest"]='secondValue'
'firstValue'
###### The value doesn’t change #########
Questions:
- What is the proper call to commit the “tw” transaction? And will the existing read transaction “see” it immediately or do I need to re-establish a new read transaction?
- Am I going about this the hard way? Is there a wrapper function/class to open a write transaction, assign a value and commit it?
- Does setting this value directly (outside of the cb_create function) create any side effects ?
- What causes the naming convention of “autovnfpair__autovnfpair” ?
                - I’ve seen other example code that doesn’t follow this pattern , but I can’t determine the difference in the yang model or code that would make this different.
previousqna
Level 8
Level 8
Inline
Hi All,
import ncs
'firstValue'
'firstValue'
Questions:
tw.apply()
the read transaction will never see the new value because it read the old value beforehand and a read transaction is supposed to give you one consistent view of the DB.
See following trace, the read transaction maintains a consistent view of the DB, so exactly what is seen immediately depends on what the read transaction has already read and is now cached in the transaction
>>> rroot.devices.device['testdev'].address
'1.2.3.4'
Now before making a change we read into the read transaction the device IP
>>> wroot.devices.device['testdev'].address='1.2.3.5'
>>> tw.apply()
'1.2.3.4'
Even though the write transaction is applied, the old avalue of the IP is still in the read transaction.
Probably not. Why not use a single transaction? There is nothing stopping you from reading in a write transaction.
No wrapper is provided, and I think in almost all cases there is more than one value to write.
It is persisted in the DB when you apply, that is an intended side effect. Otherwise no nothing harmful here at all.
You have a list called autovnfpair in a namespace called autovnfpair, python does no allow identifiers with ‘:’ so it is replaced with ‘__’. Note that in yang ‘-‘ is also a common identifier in names, that is not useable in python, and this is replaced by ‘_’.
You could just use autovpnfpair as the  identifier instead of the long form if it is unambiguous, just like I did not have to use ncs__devices
