NED --ERROR-- java uninitialized cause java path changed
yeepsae17
< Symptom >
Reloading NED packages failed.
root@ncs# packages reload
reload-result {
    package alu-sr
    result false
    info --ERROR--
reload-result {
    package cisco-iosxr
    result false
    info --ERROR--
reload-result {
    package l3vpn
    result true
reload-result {
    package huawei-vrp
    result false
    info --ERROR--
root@ncs# show packages package oper-status
        PACKAGE
                      PROGRAM                                                        META     FILE
                      CODE     JAVA           BAD NCS  PACKAGE  PACKAGE  CIRCULAR    DATA     LOAD   ERROR
NAME              UP  ERROR    UNINITIALIZED  VERSION  NAME     VERSION  DEPENDENCY  ERROR    ERROR  INFO
alu-sr            -   -        X              -        -        -        -           -        -      -
cisco-iosxr       -   -        X              -        -        -        -           -        -      -
huawei-vrp        -   -        X              -        -        -        -           -        -      -
l3vpn             X   -        -              -        -        -        -           -        -      -
< troubleshoot >
After java path was changed by any reason, once the nso restarts, java-vm doesn’t come up with this error msg in the ncs-java-vm.log,
Starting java-vm with options:\n' -classpath :/opt/ncs/current/java/jar/* -Dport=4569 -Djava.security.egd=file:/dev/./urandom -Dfile.encoding=UTF-8'
/opt/ncs/current/bin/ncs-start-java-vm: line 97: exec: java: not found
The new java path was exported in shell environment, so the ncs-start-java-vm can be executed from SHELL directly, but not started by "/etc/init.d/ncs start"
In order to find the reason why it doesn't start, I did two ways as below.
1) I modified the ncs-start-java-vm line 97 like “exec /usr/local/java/bin/java ${opts} ${mainclass}”, then it’s working.
2) I created symbolic link like 'ln -s /usr/local/java/bin/java /usr/bin/java', then it's working.
In case of local installation, it doesn't have this problem, however in case of the system installation I think the ncs-start-java-vm can't get the shell environment.
Can anyone give me better idea?
ramkraja
Is /usr/local/java/bin in your PATH when you start NSO?
You cannot change the env variables of an already running Linux process.
The environment is applied once the process is restarted.
When the NSO started, the /usr/local/java/bin was not in the PATH.
While the NSO was running, someone installed new jdk and the PATH was chagned.
So I restarted the NSO, but the new PATH was not applied.
I think you could reproduce this.
0) in the system installation,
1) remove the /usr/bin/java which should be symbolic link.
2) create the the symbolic link under the other directory which is in the PATH
3) restart the NSO (/etc/init.d/ncs restart)
4) Java VM is not running.
In case of local installation, the Java VM is running.
