Netsim device connection refused with newly created netconf NED.
sachin0987
I have created juniper ned by using ncs netconf ned creation method, but after adding a new device using the same ned getting connection refused.
Package Reload Successful and also there is no error during compilation.
reload-result {
package junosnewned
result true
admin@ncs# devices device ?
Possible completions:
 Newnedrouter TEST-DEVICE new-device
admin@ncs# devices device Newnedrouter ping
result PING 127.0.0.1 (127.0.0.1) 56(84) bytes of data.
64 bytes from 127.0.0.1: icmp_seq=1 ttl=64 time=0.040 ms
--- 127.0.0.1 ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 0.040/0.040/0.040/0.000 ms
admin@ncs# devices device Newnedrouter check-sync
result error
info Failed to connect to device Newnedrouter: connection refused
admin@ncs#
ramkraja
result error
admin@ncs#
Did you get the host keys from the device?
Try doing "devices device Newnedrouter ssh fetch-host-keys", and then try connecting to the device.
Ping works because it is over ICMP, and does not need the host-keys. To connect over SSH, NSO needs the host-keys from the device (you can disable host-key verification if you want, but it is not recommended).
/Ram
ramkraja
result error
admin@ncs#
/Ram
Or perhaps the netsim device is not running. That seems more in line with the error "connection refused".
Are you sure you started the netsim device?
/Ram
Yes, Already running.
Hi Ram ,
Thanks for your response, after restart the ncs and netsim,It works.I don't know about the actual issue.
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
