NSO and 8000v router
m.rotteveel
not sure if this is the correct place to ask, so any redirection is welcome.
I'm trying to configure NSO to use a 8000v virtual router running "Cisco IOS XE Software, Version 17.04.01a".
Everything looks ok, it connects, syncs-from and syncs-to, pings, etc.
But when i do a " show running-config devices device *" it only shows very basic info like ip, host-key, device type.
(the only things that are configured in NSO, not from the device itself)
i'm researching the NED i use, but tested all of them without success.
any ideas ?
Martijn.
vleijon
Well, does what you see match what is actually configured on the device? If not I’d try a good NED, if you are a customer use the latest available to you, if not you can get a decent one here: https://developer.cisco.com/docs/nso/#!getting-and-installing-nso/requirements
