NSO CLI - enforcing password prompt
suvdeshm
Is there any rule or setting so that for cli access user has to enter password.
rhinst001
Level 2
Level 2
I don't believe so (as documented here), but you can set up an IPC shared secret. It's not the same as performing per-user authentication against your PAM modules or whatever, but at least it's some layer of security above unauthenticated access.
vleijon
The best way is to make users ssh into the nso ssh server directly.
