NETCONF/YANG
Hello everyone,
I am still new in the NETCONF/YANG and NSO field and I would like to ask some questions:
      1- How am I supposed to edit the YANG file?
       2- I have made a NETCONF device on NSO but how would I like to manipulate the configurations?
I would really appreciate it if someone provided me with real examples of changing the basic configuration on the devices by NETCONF/YANG such as (adding interfaces and IP etc).
Thanks in advance.
Nabsch
Concerning your first question , are you talking about editing yang inside a package ? or something else ?
Concerning your second question , it depend on your vendor. On some vendor, you have some CLI command that allow you to translate CLI command to NETCONF. Otherwise a simple solution:
  1. You have to use a NETCONF NED and CLI NED .
  2. You onboard the device two times using ( device using CLI NED and another using NETCONF ) that refer to the same device
  3. You do a sync-from for the 2 devices
  4.  You edit the device using CLI NED
  5. You do a compare-config  outformat XML on the device that using the NETCONF NED and you will get the XML  template
Nabsch
