NSO configuration rollback failed using labels
ashoklak
Feature/Capability to rollback using Labels (instead of using just Rollback ID) using NSO
 We are using NSO for our Automation efforts. Part of this we wanted to create a functionality to rollback all the changes made under a Change Request Number. This can be useful for us and other NSO Clients to scale the rollback to multiple rollback ID's instead of fetching several rollback ID's
We tried to roll back the configuration and it works with ID( Fixed number) “10207”  but when we tried with the label “CHG234567” it’s getting failed  ,so we need confirmation as whether rollback is possible only with iD (Fixed number) and not with Labels as below and also Do we have any Functionality of rollback with labels in the Future version of NSO.
admin@ncs(config)# show configuration commit list
2022-01-13 12:16:24**EnterYourText**
SNo.  ID       User       Client      Time Stamp          Label       Comment
10207 10207    rachanti   rest        2022-01-13 12:11:11 CHG234567   epg_dn: uni/tn-common/ap-ceph-storage-anp/epg-ceph-internal-01-epg, fvRsPathAtt: topology/pod-1/protpaths-1021-1022/pathep-[svl-ceph-103-0-IfPolGrp]
10206 10206    rachanti   rest        2022-01-13 12:10:04
10205 10205    rachanti   rest        2022-01-13 12:06:30
10204 10204    rachanti   rest        2022-01-13 12:05:54 CHG1234567  epg_dn: uni/tn-common/ap-ceph-storage-anp/epg-ceph-internal-01-epg, fvRsPathAtt: topology/pod-1/protpaths-1021-1022/pathep-[svl-ceph-103-0-IfPolGrp]
10203 10203    rachanti   rest        2022-01-13 12:05:20
10202 10202    rachanti   rest        2022-01-13 11:59:00
10201 10201    rachanti   rest        2022-01-13 11:57:29 CHG1234567  epg_dn: uni/tn-common/ap-ceph-storage-anp/epg-ceph-internal-01-epg, fvRsPathAtt: topology/pod-1/protpaths-1021-1022/pathep-[svl-ceph-103-0-IfPolGrp]
10200 10200    rachanti   rest        2022-01-13 11:56:40
admin@ncs# config t
Entering configuration mode terminal
admin@ncs(config)# rollback selective 10204
admin@ncs(config)# rollback selective CHG234567
syntax error: "CHG234567" is not a valid value.
admin@ncs(config)#
vleijon
You do have to use the key, which is the id. You can potentially use a query or just a show command to map between keys and labels. There is however no general guarantee that labels are unique.
