NSO Core Function Pack PNP Installation
WilliamWhitfield41805
Frequent Visitor
Frequent Visitor
From my understanding, the packages within the core function pack are precompiled, however I am receiving errors when trying to do 'packages reload' I receive the following error:
/etc/ncs/ncs.conf:0: /var/opt/ncs/state/packages-in-use/1/pnp-service/load-dir/tailf-ned-nano-services-pnp.fxs: Must be recompiled
Currently using NSO v5.4.1.1 and Core function pack version 3.0
sunge
Most likely the release of PNP you are using, is not released or built for the version of NSO you are using. What is the full name
of the PNP package?
The full file name is ncs-5.3.0.1-cisco-pnp-project-2.3.5.signed.bin
sunge
Right, then it is built for NSO 5.3, and will only work on 5.3.x versions of NSO.
I see that we have not actually released a build for 5.4 or 5.5 of NSO, I'll see if I can make that happen.
