NSO-developer / nso-xr-segmentrouting ( First Time Setup Error)
ZAhmad04890
Level 2
Level 2
Hi ,
I am trying to run the example located at https://github.com/NSO-developer/nso-xr-segmentrouting
my OS is Ubuntu 18.04 LTS and using NSO 5.3
ahmad@ahmad:~/ncs-run/nso-xr-segmentrouting-develop/packages/resource-manager$ java --version
openjdk 11.0.10 2021-01-19
OpenJDK Runtime Environment (build 11.0.10+9-Ubuntu-0ubuntu1.18.04)
OpenJDK 64-Bit Server VM (build 11.0.10+9-Ubuntu-0ubuntu1.18.04, mixed mode, sharing)
following the README.md guide lines ,  I am getting the error as shown below, kindly advise any resolution to this error. "package.mk:375: recipe for target 'src/java/build/.built' failed".
Thanks.
Getting Started : Setup Netsim and NCS Environment
First Time Setup
  1. cd packages/resource-manager/ make clean all
ahmad@ahmad:~/ncs-run/nso-xr-segmentrouting-develop/packages/resource-manager$ make clean all
awk: not an option: --field-separator=-
package.mk:486: warning: overriding recipe for target 'src/java/src/com/tailf/pkg/ipaddressallocator/namespaces/'
package.mk:486: warning: ignoring old recipe for target 'src/java/src/com/tailf/pkg/ipaddressallocator/namespaces/'
package.mk:486: warning: overriding recipe for target 'src/java/src/com/tailf/pkg/idallocator/namespaces/'
package.mk:486: warning: ignoring old recipe for target 'src/java/src/com/tailf/pkg/idallocator/namespaces/'
=== Clean resource-manager
=== Clean id-loop
=== Clean ip-loop
=== Clean ipaddress-allocator-test
=== Clean pool-service
=== Build resource-manager
warning: No processor claimed any of these annotations: java.base/java.lang.Deprecated,/com.tailf.dp.annotations.ValidateCallback,java.base/java.lang.Override,/com.tailf.ncs.annotations.Resource,/com.tailf.dp.annotations.TransValidateCallback
/home/ahmad/ncs-run/nso-xr-segmentrouting-develop/packages/resource-manager/src/java/src/com/tailf/pkg/idallocator/AllocationsSet.java:8: error: cannot find symbol
import com.tailf.pkg.idallocator.namespaces.idAllocatorOper;
symbol: class idAllocatorOper
/home/ahmad/ncs-run/nso-xr-segmentrouting-develop/packages/resource-manager/src/java/src/com/tailf/pkg/idallocator/IdAllocator.java:46: error: cannot find symbol
/home/ahmad/ncs-run/nso-xr-segmentrouting-develop/packages/resource-manager/src/java/src/com/tailf/pkg/idallocator/RangeSet.java:8: error: cannot find symbol
/home/ahmad/ncs-run/nso-xr-segmentrouting-develop/packages/resource-manager/src/java/src/com/tailf/pkg/ipaddressallocator/AllocationsSet.java:8: error: cannot find symbol
import com.tailf.pkg.ipaddressallocator.namespaces.ipaddressAllocatorOper;
symbol: class ipaddressAllocatorOper
location: package com.tailf.pkg.ipaddressallocator.namespaces
/home/ahmad/ncs-run/nso-xr-segmentrouting-develop/packages/resource-manager/src/java/src/com/tailf/pkg/ipaddressallocator/AvailablesSet.java:9: error: cannot find symbol
5 errors
1 warning
BUILD FAILED
/home/ahmad/ncs-run/nso-xr-segmentrouting-develop/packages/resource-manager/src/java/build.xml:38: Compile failed; see the compiler error output for details.
Total time: 2 seconds
Michael Maddern
Hi, it looks like Ubuntu uses mawk by default, which doesn't support the field-separator option. If you install gawk, that should fix the problem:
sudo apt-get install gawk
5 Replies 5
Alexander Stevenson
Hi @ZAhmad04890,
While I'm not an expert in this area, I'd like to bring a couple of possibilities to your attention:
Modules Importing themselves, etc - Cisco Community Forums - NSO Developer Hub Discussions
Java compilation / package / namespace error (EXTERNAL LINK - Stack Overflow)
Hope this helps!
ZAhmad04890
Level 2
Level 2
Hi Alex,
Thanks for your reply, I noticed I have NSO 5.3 installed (thanks to Devnet for providing it for free) , but I have not installed " Resource Manager Package bundle for NSO 5.3" which Includes (ID allocator and IP allocator packages) . Is there any workaround to go around this Resource Allocator package? like assigning the IDs and IPs inside python code etc ? , as I do not have permissions to download this package from Cisco.com, neither it is available on Devnet for free download. ?
Thanks.
Michael Maddern
Hi Michael,
Thanks for your reply, This command works and package is now make successfully!!!
admin@ncs# packages reload
reload-result {
package cisco-iosxr-cli-7.18
result true
reload-result {
package disable-ldp
result true
reload-result {
package resource-manager
result true
[snip]
As a side note, there are some warnings shown in the output below (about 70), I am not sure if these warnings are because of ubuntu 18.04 and would these impact the operational aspect of resource-manager package or not ?
warnings output is shown  as below.
make[1]: Entering directory '/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src'
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/idallocator/AllocationsSet.java:22: warning: [deprecation] Logger in org.apache.log4j has been deprecated
private static Logger LOGGER = Logger.getLogger(AllocationsSet.class);
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/idallocator/IdAllocator.java:86: warning: [deprecation] Logger in org.apache.log4j has been deprecated
private static Logger LOGGER = Logger.getLogger(IdAllocator.class);
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/idallocator/IdAllocator.java:350: warning: [deprecation] container(String,String) in NavuContainer has been deprecated
root.container(resourceAllocator.prefix,
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/idallocator/IdAllocator.java:352: warning: [deprecation] list(String,String) in NavuContainer has been deprecated
idpool = resources.list(idAllocator.prefix, idAllocator._id_pool_);
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/idallocator/IdAllocator.java:368: warning: [deprecation] list(String,String) in NavuContainer has been deprecated
resources.list(idAllocator.prefix, idAllocator._id_pool_).
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/idallocator/IdAllocator.java:841: warning: [deprecation] container(String,String) in NavuContainer has been deprecated
NavuContainer resources = root.container(resourceAllocator.prefix,
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/idallocator/IdAllocator.java:845: warning: [deprecation] list(String,String) in NavuContainer has been deprecated
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/idallocator/IdAllocator.java:959: warning: [deprecation] container(String,String) in NavuContainer has been deprecated
navuPool.container(idAllocatorOper.prefix, idAllocatorOper._range_);
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/idallocator/IdAllocator.java:972: warning: [deprecation] list(String,String) in NavuContainer has been deprecated
NavuList poolExclude = navuPool.list(idAllocatorOper.prefix,
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/idallocator/IdAllocator.java:1322: warning: [deprecation] list(String,String) in NavuContainer has been deprecated
NavuContainer transPool = transRoot.container(resourceAllocator._resource_pools).
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/idallocator/IdAllocator.java:1647: warning: [deprecation] container(String,String) in NavuContainer has been deprecated
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/idallocator/IdAllocator.java:1656: warning: [deprecation] list(String,String) in NavuContainer has been deprecated
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/nsoutil/Pool.java:17: warning: [deprecation] Logger in org.apache.log4j has been deprecated
private static final Logger LOGGER = Logger.getLogger(Pool.class);
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/idpool/IDPool.java:17: warning: [deprecation] Logger in org.apache.log4j has been deprecated
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/idallocator/RangeSet.java:22: warning: [deprecation] Logger in org.apache.log4j has been deprecated
private static Logger LOGGER = Logger.getLogger(RangeSet.class);
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/ipaddressallocator/AllocationsSet.java:22: warning: [deprecation] Logger in org.apache.log4j has been deprecated
private static final Logger LOGGER = Logger.getLogger(AllocationsSet.class);
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/ipaddressallocator/AvailablesSet.java:21: warning: [deprecation] Logger in org.apache.log4j has been deprecated
private static Logger LOGGER = Logger.getLogger(AvailablesSet.class);
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/ipaddressallocator/IPAddressAllocator.java:47: warning: [deprecation] Logger in org.apache.log4j has been deprecated
private static final Logger LOGGER = Logger.getLogger(IPAddressAllocator.class);
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/ipaddressallocator/IPAddressAllocator.java:192: warning: [deprecation] container(String,String) in NavuContainer has been deprecated
root.container(resourceAllocator.prefix, resourceAllocator._resource_pools_);
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/ipaddressallocator/IPAddressAllocator.java:194: warning: [deprecation] list(String,String) in NavuContainer has been deprecated
resources.list(ipaddressAllocator.prefix, ipaddressAllocator._ip_address_pool_);
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/ipaddressallocator/IPAddressAllocator.java:483: warning: [deprecation] container(String,String) in NavuContainer has been deprecated
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/ipaddressallocator/IPAddressAllocator.java:485: warning: [deprecation] list(String,String) in NavuContainer has been deprecated
resources.list(ipaddressAllocator.prefix, ipaddressAllocator._ip_address_pool_).
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/ipaddressallocator/IPAddressAllocator.java:571: warning: [deprecation] list(String,String) in NavuContainer has been deprecated
NavuList poolSubnet = pool.list(ipaddressAllocator.prefix,
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/ipaddressallocator/IPAddressAllocator.java:643: warning: [deprecation] list(String,String) in NavuContainer has been deprecated
NavuList poolExclude = pool.list(ipaddressAllocator.prefix,
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/ipaddressallocator/IPAddressAllocator.java:1066: warning: [deprecation] list(String,String) in NavuContainer has been deprecated
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/ipaddressallocator/IPAddressAllocator.java:1391: warning: [deprecation] container(String,String) in NavuContainer has been deprecated
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/ipaddressallocator/IPAddressAllocator.java:1394: warning: [deprecation] list(String,String) in NavuContainer has been deprecated
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/ipaddressallocator/IPAddressAllocator.java:1649: warning: [deprecation] container(String,String) in NavuContainer has been deprecated
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/ipaddressallocator/IPAddressAllocator.java:1659: warning: [deprecation] list(String,String) in NavuContainer has been deprecated
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/ipam/IPAddressPool.java:26: warning: [deprecation] Logger in org.apache.log4j has been deprecated
private static Logger LOGGER = Logger.getLogger(IPAddressPool.class);
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/ipaddressallocator/IPValidator.java:23: warning: [deprecation] Logger in org.apache.log4j has been deprecated
private static final Logger LOGGER = Logger.getLogger(IPValidator.class);
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/ipam/util/InetAddressRange.java:32: warning: [deprecation] Logger in org.apache.log4j has been deprecated
private static final Logger LOGGER = Logger.getLogger(InetAddressRange.class);
/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src/java/src/com/tailf/pkg/nsoutil/NSOUtil.java:20: warning: [deprecation] Logger in org.apache.log4j has been deprecated
private static final Logger LOGGER = Logger.getLogger(NSOUtil.class);
70 warnings
make[1]: Leaving directory '/home/ahmad/ncs-run/xr-segmentrouting-local-resource/packages/resource-manager/src'
Hi - I see the same warnings when I compile, you can ignore them, the package still works okay.
