NSO doing rollback programmatically
sm000x
Level 5
Level 5
I have a question about NSO rollback.
Can I do rollback programmatically?
if I have a service model touches device then later user wants to rollback. Can
user send a request to NSO and NSO rollback the configuration programmatically?
THX
sm000x
2 Accepted Solutions
hniska
the right thing todo is to delete the service (or do an undeploy if you just want to remove the config from the devices but keep the service data). You do not want to fiddle around with the rollback files for things like this.
hniska
but yes you can rollback programmatically, you can read up on rollbacks a bit more here https://developer.cisco.com/docs/nso/guides/#!rollbacks/rollbacks
5 Replies 5
hniska
Thank you very much.
hniska
Thank you very much for the information.
sm000x
Level 5
Level 5
Hi, hniska:
I read https://developer.cisco.com/docs/nso/guides/#!rollbacks/rollbacks, however, there is no example code there.
Do you have a simple rollback java code anywhere?
THX
