NSO Error
Ayeisha07
Community Member
Has anyone encountered this error when installing NSO? This occurs after I run the sh nso-4.7.linux.x86_64.signed.bin command during setup.
Error log: Failed to convert crcam2.cerfrom DER to PEM.
Error log: unable to load certificate
joepak
What version of OpenSSL are you using? Can you utilize the latest version of OpenSSL and see if the issue is fixed?
pbarcins
If you are using Ubuntu, you have to follow instructions:
https://websiteforstudents.com/manually-install-the-latest-openssl-toolkit-on-ubuntu-16-04-18-04-lts/
this should solve your issue
