NSO - IOS XML Template for xconnect section - MTU problem
Maurizio Bau
Hi All
I created an NSO Packages to modify following ios configuration on l2vpn istance, (for example 7609 )
interface GigabitEthernet9/1
 description porta per TEST NSO
 mtu 9216
 service instance 150 ethernet
  encapsulation dot1q 150
  rewrite ingress tag pop 1 symmetric
  xconnect 172.16.12.1 250150 encapsulation mpls
   backup peer 1.1.1.1 4562
   mtu 9202
In my package, I created an xml template similiar like that
<interface xmlns="urn:ios">
	<GigabitEthernet when="{$remotePortType = 'GigabitEthernet'}">
	<name>{$remotePortId}</name>
		<service>
			 <instance>
				<id>{$remoteServiceInstance}</id>
				<xconnect tags="merge">
				 <address>{$localL9New}</address>
				<vcid>{$pwIdNew}</vcid>
					  <backup>
						<peer>
						  <peer-router-ip-addr>{$neighborRemoteBk}</peer-router-ip-addr>
						  <vcid>{$pwIdRemoteBk}</vcid>
						</peer>
					  </backup>
					  <mtu>{$remoteMtu}</mtu>
					</xconnect>
				  </instance>
				</service>
			</GigabitEthernet>
After Packages Reload, I don't have error o log, but when I commit a packages I see different problem
  1. MTU on xconnect section are not present on the device but are present on NSO DB configuration
    •  service instance 150 ethernet
        xconnect 172.16.12.2 4545656 encapsulation mpls
      devices device A1-MDR
       config
        ios:interface GigabitEthernet9/1
         no switchport
           no mpls control-word
           mtu 9202
          exit
         exit
  2. When i launch Rollaback session, MTU value are not present on Device.
I tried to use different tags on xml xconncet section or xml mtu section, create, merge, replace, without solution.
I tried to use xconnect with tag "delete" and section with tag "create" but without to reach a goal.
Do you have any idea?
Thanks a lot for any indication
Bye Bye
Maurizio
6 Replies 6
rogaglia
Do the following and re-post:
1) Do a show running of the interface in NSO before committing the service.
2) Try to debug your problem via:
#commit dry-run | debug template
3) When the service is committed, try to run:
#show running myservice myserviceinstance | show service-meta
The second will give more insights into the insights of NSO.
Roque
Hi Roque
Thanks a lot for your replay.
I maked your steps and this is the results
 description porta per TEST NSO Valerio
 mtu 9216
   mtu 9202
In following code, section about IOS template, in attached file "Debug", all log
Context node: /services/movePWService:movePWService[name='mau2']
Result: "A1-MDR"
Operation 'merge' on existing node: /devices/device[name='A1-MDR'] (from file "OPM-Feeder-IOS.xml", line 45)
Evaluating conditional expression "boolean($remotePortType = 'GigabitEthernet')" (from file "OPM-Feeder-IOS.xml", line 73)
Result: true - continuing
Evaluating "$remotePortId" (from file "OPM-Feeder-IOS.xml", line 74)
Result: "9/1"
Operation 'merge' on existing node: /devices/device[name='A1-MDR']/config/ios:interface/GigabitEthernet[name='9/1'] (from file "OPM-Feeder-IOS.xml", line 74)
Evaluating "$remoteServiceInstance" (from file "OPM-Feeder-IOS.xml", line 77)
Result: "150"
Operation 'merge' on existing node: /devices/device[name='A1-MDR']/config/ios:interface/GigabitEthernet[name='9/1']/service/instance[id='150'] (from file "OPM-Feeder-IOS.xml", line 77)
Operation 'merge' on existing node: /devices/device[name='A1-MDR']/config/ios:interface/GigabitEthernet[name='9/1']/service/instance[id='150']/xconnect (from file "OPM-Feeder-IOS.xml", line 78)
Operation 'replace' on node: /devices/device[name='A1-MDR']/config/ios:interface/GigabitEthernet[name='9/1']/service/instance[id='150']/xconnect/address (from file "OPM-Feeder-IOS.xml", line 79)
Evaluating "$localL9New" (from file "OPM-Feeder-IOS.xml", line 79)
Result: "172.16.12.2"
Setting /devices/device[name='A1-MDR']/config/ios:interface/GigabitEthernet[name='9/1']/service/instance[id='150']/xconnect/address to "172.16.12.2"
Operation 'replace' on node: /devices/device[name='A1-MDR']/config/ios:interface/GigabitEthernet[name='9/1']/service/instance[id='150']/xconnect/vcid (from file "OPM-Feeder-IOS.xml", line 80)
Evaluating "$pwIdNew" (from file "OPM-Feeder-IOS.xml", line 80)
Result: "4545656"
Setting /devices/device[name='A1-MDR']/config/ios:interface/GigabitEthernet[name='9/1']/service/instance[id='150']/xconnect/vcid to "4545656"
Evaluating conditional expression "boolean($neighborRemoteBk != 'None')" (from file "OPM-Feeder-IOS.xml", line 81)
Result: false - skipping siblings
Operation 'merge' on existing node: /devices/device[name='A1-MDR']/config/ios:interface/GigabitEthernet[name='9/1']/service/instance[id='150']/xconnect/mtu (from file "OPM-Feeder-IOS.xml", line 87)
Fetching literal "9202" (from file "OPM-Feeder-IOS.xml", line 87)
Setting /devices/device[name='A1-MDR']/config/ios:interface/GigabitEthernet[name='9/1']/service/instance[id='150']/xconnect/mtu to "9202"
nso@ncs# show running-config services movePWService mau2 | display service-meta-data
mdrSrcName OPM-9K1-F1
mdrSrcIf GigabitEthernet0/4/1/7
peSrcName OPM-RGJIT001
peSrcIf xe-1/0/0
peSrcUnit 250
peSrcSvlan 250
peSrcCvlan 1000
mdrDstName OPM-9K1-F2
mdrDstIf TenGigE0/6/0/4
peDstName OPM-RGJIT001
peDstIf xe-1/0/0
peDstUnit 250
nso@ncs#
You can see IOS Template in attached rar file,
Grazie
Bye
Maurizio
hi,
I shoudl have say that you need to get the device configuration service meta data:
nso@ncs# show running-config device device Mydevice config ios:interface | display service-meta-data
However, I believe NSO is working as designed. NSO will return the the original configuration when deleted, which in this case is the MTU configured.
Service "redeploy reconcilate" will allow you to change the behavior. It is well explained in the developer guides.
Roque
@rogaglia wrote:
hi,
No problems, logs are free... :-)
Service-meta-data log on IOS device by NSO showing this configuration
nso@ncs# show running-config devices device A1-MDR config ios:interface GigabitEthernet 9/1 | display service-meta-data
 config
  ! Refcount: 2
  ! Backpointer: [ /ncs:services/movePWService:movePWService[movePWService:name='mau2'] ]
   no switchport
   ! Refcount: 2
    service-policy input IN
    service-policy output OUT
    ! Refcount: 2
    xconnect 172.16.12.2 753159 encapsulation mpls
     ! Refcount: 2
     ! Originalvalue: 9202
     mtu 9202
    exit
   exit
I’m going to read the developers guide, but the service re-deploy reconcilate doesn’t seem to work.
nso@ncs# services movePWService mau2 re-deploy reconcile
Error: no registration found for callpoint movePWService-servicepoint/service_create of type=external
nso@ncs# *** ALARM service-activation-failure: no registration found for callpoint movePWService-servicepoint/service_create of type=external
nso@ncs(config)# services movePWService mau2 re-deploy reconcile
nso@ncs(config)#
So, Thanks a lot for your response and I'll write in this post if i find some solution/indication
Have a nice day
Ciao
Maurizio
Hi Maurizio,
Two points
1) You have a problem with your package as a callback is not found. You probably need to check it for errors and do a "package reload".
2) If you seem you have one Backpointer and RefCount=2. This means that when the service will be deleted, the values will be left as they are or returned to its original value, instead of deleting them.
Try your service by first deleting the target config in the device. There, the RefCount will be =1 and the config will be deleted when deleting the service.
Roque
Hi Roque
Sorry for delay response and thanks for continou feedback to solve a problem
I followed your indication but i don't found a solution or one key to solve a problem.
I checked my packages, I verified python section about IOS apply template and controlled my template but i don't know if.... "there is light at the end of the tunnel" :-(
So,
I created a Case report pdf file to aggregate all steps on this test
- Clear all services
- Start config with MTU 9202
- Config service
- Commit dryrun with debug template
- commit
- Verify RefCount ( Not change, RefCount remain on value "2")
- Rollback
For all detail, please see the attached pdf file.
At the same time, I showed the IOS-XR configuration about same services, and I found RefCount ugual 1
nso@ncs# show running-config devices device OPM-9K1-F2 config cisco-ios-xr:interface TenGigE 0/6/0/4.251 | display service-meta-data
 config
  ! Refcount: 1
  ! Backpointer: [ /ncs:services/movePWService:movePWService[movePWService:name='mau3'] ]
  cisco-ios-xr:interface TenGigE 0/6/0/4.251 l2transport
   encapsulation dot1q 2 second-dot1q 251
   no shutdown
   ! Refcount: 1
   rewrite ingress tag pop 2 symmetric
  exit
Test Nr 2 - Modify backup xconnect configuration
To clear all doubts about IOS template, I created a second template to modify backup xconnect configuation
IOS CLI Configuration
 mtu 9216
 service instance 250 ethernet
  encapsulation dot1q 250
  xconnect 172.16.12.7 7777250 encapsulation mpls
   backup peer 172.16.12.1 250250
   mtu 9202
IOS BK XML Template
---- Part of XML BACKUP IOS TEMPLATE ----
<interface xmlns="urn:ios"> <GigabitEthernet when="{$remotePortType = 'GigabitEthernet'}"> <name>{$remotePortId}</name> <service> <instance> <id>{$remoteServiceInstance}</id> <xconnect> <address>{$neighborRemote}</address> <vcid>{$pwIdRemote}</vcid> <encapsulation>mpls</encapsulation> <backup tags="delete"> </backup> <backup> <peer> <peer-router-ip-addr>{$localL9New}</peer-router-ip-addr> <vcid>{$pwIdNew}</vcid> </peer> </backup> <mtu>9202</mtu> </xconnect> </instance> </service> </GigabitEthernet>
I execute the same services, but this time I don't have any problem, BackUp are correctly modified and MTU are not erased
I verified also the service-meta-data and also in this case, I have a RefCount egual to "2"
 config
  ! Refcount: 2
   no switchport
   ! Refcount: 2
    ! Refcount: 2
     ! Refcount: 2
     ! Originalvalue: 172.16.12.1
     backup peer 172.16.12.2 999999
     ! Refcount: 2
     mtu 9202
    exit
   exit
Test Nr 3 - Clear all service instance and recreate with same number configuration
I tried also with delete the service instance on xml template and create but the problem remain the same.
 config
  ! Refcount: 2
   no switchport
   ! Refcount: 2
    ! Refcount: 2
    xconnect 172.16.12.2 1234567 encapsulation mpls
     ! Refcount: 2
     mtu 9202
    exit
   exit
Last Test - New packages IOS
I created a new packages, without python logic and only with 1 template xml. This packages remove only shutdown configuration on a GIgabitEthernet interface.
The goal of this are to verify RefCount value
<config-template xmlns="http://tail-f.com/ns/config/1.0"
                 servicepoint="port-turn-up">
  <devices xmlns="http://tail-f.com/ns/ncs">
    <device>
     <name>{/device}</name>
      <config>
		<GigabitEthernet>
			<name>{/interface_id}</name>
			<shutdown tags="delete"></shutdown>
		</GigabitEthernet>
       </interface>
      </config>
    </device>
  </devices>
</config-template>
When I lanch the services, debug template are simply this
nso@ncs(config-port-turn-up-TestRFCOUNT)# commit dry-run | debug template
Evaluating "/device" (from file "port-turn-up-template.xml", line 10)
Context node: /services/port-turn-up:port-turn-up[name='TestRFCOUNT']
Result:
For /services/port-turn-up:port-turn-up[name='TestRFCOUNT'], it evaluates to "A1-MDR"
Operation 'merge' on existing node: /devices/device[name='A1-MDR'] (from file "port-turn-up-template.xml", line 10)
The device /devices/device[name='A1-MDR'] does not support namespace 'http://tail-f.com/ned/cisco-ios-xr' for node "interface" (from file "port-turn-up-template.xml", line undefined)
Skipping...
Evaluating "/interface_id" (from file "port-turn-up-template.xml", line 20)
Result:
For /services/port-turn-up:port-turn-up[name='TestRFCOUNT'], it evaluates to "9/5"
Operation 'merge' on existing node: /devices/device[name='A1-MDR']/config/ios:interface/GigabitEthernet[name='9/5'] (from file "port-turn-up-template.xml", line 20)
Operation 'delete' on node: /devices/device[name='A1-MDR']/config/ios:interface/GigabitEthernet[name='9/5']/shutdown (from file "port-turn-up-template.xml", line 21)
cli {
    local-node {
        data  devices {
                  device A1-MDR {
                      config {
                          ios:interface {
                              GigabitEthernet 9/5 {
             -                    shutdown;
              services {
             +    port-turn-up TestRFCOUNT {
             +        device A1-MDR;
             +        interface_type GigabitEthernet;
             +        interface_id 9/5;
After commit, the RefCount on this interface are..
nso@ncs# show running-config devices device A1-MDR config ios:interface GigabitEthernet 9/5 | display service-meta-data
 config
  ! Refcount: 2
  ! Backpointer: [ /ncs:services/port-turn-up:port-turn-up[port-turn-up:name='TestRFCOUNT'] ]
  ios:interface GigabitEthernet9/5
   no switchport
   no ip address
   no shutdown
  exit
nso@ncs#
Maybe I will make a mistake, but it would seem that ned IOS always sets RefCount to 2
I hope all tests are clear
Maurizio
