NSO Junos NED request-shell-execute
denoia
Community Member
we are trying to use Rpc  request-shell-execute in ned juniper-junos 4.2.1.
This Rpc emulates the execution of a cli command in juniper shell.
For example
cli show configuration vlans VLAN-755
returns
description PROVA_INTERNAL;
vlan-id 755;
My question is about concatenation of commands through "|"
for example
cli show configuration | display set |match VLAN-755
returns
display: Command not found.
match: Command not found.
cli: remote side unexpectedly closed connection
Is there a way to fire concatenated commands though this RPC?
Thanks in advance,
Giuseppe
Please issue a TAC ticket and the NED developer will add the missing commands. This is typical work on NEDs. In particular, remember that Juniper original API was based on NETCONF but not YANG. So, we need to semi-automatically translate from the Juniper proprietary XSD to YANG and that is done by the NED team.
reparab
Escape character '\' needs to be added to any special character in the command like below:
cli show configuration \| display set \|match VLAN-755
rogaglia
There is an example in the NED README file:
admin@ncs# devices device mx960-1 rpc rpc-request-shell-execute request-shell-execute command "cli request unified-edge sgw call-trace show brief \| display json"
In your case, that woudl translate to:
admin@ncs# devices device mx960-1 rpc rpc-request-shell-execute request-shell-execute command "cli show configuration \| display set \| match VLAN-755"
Hi Roque
I'm read your post and i've similar question
I want configure this command on Junos Device
set interface xe-5/0/1 unit 4017 family pppoe dynamic-profile FTTH-profile
At this time, my NED version not supported this command; as you can see, after family section there isn't a pppoe section
nso@ncs(config)# devices device OPM-RGJIT001 config junos:configuration interfaces interface xe-1/2/0 unit 4017 family ?
Possible completions:
  any                   Parameters for 'any' family
  apply-groups
  apply-groups-except
  apply-macro
  bridge                Layer-2 bridging parameters
  ccc                   Circuit cross-connect parameters
  ethernet-switching    Ethernet switching parameters
  fibre-channel         Fibre channel switching parameters
  inet                  IPv4 parameters
  inet6                 IPv6 protocol parameters
  iso                   OSI ISO protocol parameters
  mlfr-end-to-end       Multilink Frame Relay end-to-end protocol parameters
  mlfr-uni-nni          Multilink Frame Relay UNI NNI protocol parameters
  mlppp                 Multilink PPP protocol parameters
  mpls                  MPLS protocol parameters
  tcc                   Translational cross-connect parameters
  vpls                  Virtual private LAN service parameters
So, I try to use rpc request-shell command
devices device OPM-RGJIT001 rpc rpc-request-shell-execute request-shell-execute command "cli edit private\nset interfaces xe-1/2/0 unit 4017 family pppoe dynamic-profile FTTH-profile \ncommit and-quit"
nso@ncs# devices device OPM-RGJIT001 rpc rpc-request-shell-execute request-shell-execute command "cli edit private\nset interfaces xe-1/2/0 unit 4018 family pppoe dynamic-profile RESIDENTIAL-NGN2-FTTH\n commit and-quit"
output Entering configuration mode
set: Variable name must contain alphanumeric characters.
commit: Command not found.
I try to use "\" first minus simbol or number without success.
Do you have any idea to solve this issue?
thanks for you support
Bye
Maurizio
