NSO NED Build Error: /src/nid/build-pyvenv: not found
Aaron Shaw
When attempting to build a Docker image for cisco-ios-cli-6.86 using a ned skeleton on WSL2 (Windows Subsystem for Linux)
I get the following error:
#9 0.579 /bin/sh: 1: /src/nid/build-pyvenv: not found
I've attached the build log. I worked for the better part of the day on this, and am running out of ideas on what is missing. Hopefully someone here can spot something simple I have overlooked, or explain something about this error that I'm missing.
Aaron Shaw
All right, after another 2 hours, I figured out it out. It was in fact a line ending problem. My very quick and dirty fix was to install dos2unix and then fix all the files in /src/nid.
RUN apt-get update && apt-get install -y dos2unix
RUN dos2unix /src/nid/*
edit: by setting #
git config --global core.autocrlf input
I can make sure that the proper line endings are correctly applied when I clone.
Aaron Shaw
I'm wondering if my problem is similar to this "file not found" issue.
Aaron Shaw
edit: by setting #
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
