NSO Scheduler is not working
rvijende
nso scheduler is not working as per the scheduled time.
under "nacm groups" after adding the user to respective group,  nso scheduler task is not initiating.
sync action-name sync-from schedule "14 17 * * *" action-node /devices
show scheduler task is-running
is-running false
Please assist any one to fix this issue
gschudel
why do you suspect it's not working?
the task you have, with the given crontab inputs will only run once-per-day... at 17:14
2018-05-20 17:14:00 UTC
2018-05-21 17:14:00 UTC
2018-05-22 17:14:00 UTC
2018-05-23 17:14:00 UTC
2018-05-24 17:14:00 UTC
have you given sufficient time to allow it to run?
note the "is-running false" just means "it is not currently executing" -- it is oper-data if you check the yang module for "scheduler"
      leaf is-running {
        description
          "Whether the task is currently executing.";
        type boolean;
        default false;
        config false;
        tailf:cdb-oper  {
          tailf:persistent false;
Since your task runs only once-per-day it seems randomly difficult to check the execution at that particular moment.
you may best just check "show scheduler task sync history | notab" to see if any history is given.
