Kickers on operational data
christopherhamer
Community Member
NSO 4.4.4
I can create kickers to monitor configuration data and it works well. For example:
admin@ncs% show kickers data-kicker mytestkicker
monitor     /ncs:devices/ncs:device/ncs:netconf-notifications/ncs:subscription[ncs:name='tailf_nfvo']/ncs:status;
kick-node   /encstnt[hostname='mydevice'];
action-name exeaction;
Is it possible to monitor operational data using kickers, I am thinking of monitoring alarm state?
admin@ncs> show alarms alarm-list alarm virtualNetsim_mydevice connection-failure is-cleared | display xpath
/alarms/alarm-list/alarm[device='virtualNetsim_mydevice'][type='al:connection-failure'][managed-object="/ncs:devices/ncs:device[ncs:name='virtualNetsim_mydevice']"][specific-problem='']/is-cleared false
When configuring a kicker to monitor this data, it is accepted with no errors in devel.log.
Thanks!
Nickolay Belchugov
Hi Cristopher,
Kickers can monitor operational data, as well. Usually I monitor service's Plan Component.
Nickolay Belchugov
Hi Cristopher,
