NSO: Something wrong with Python process. dlopen, Symbol not found: _PyIOBase_Type
bfinnema
When installing NSO 5.3.1.1 on my Mac, and running a service, i get this:
admin@ncs(config-my_test-TEST1)# commit dry-run outformat xml
Aborted: no registration found for callpoint my_test-servicepoint/service_create of type=external
Packages oper-status. Python is not initialized for the my_test package.
admin@ncs# show packages package oper-status
        PACKAGE
                          PROGRAM        META     FILE
                          CODE     JAVA           PYTHON         BAD NCS  PACKAGE  PACKAGE  CIRCULAR    DATA     LOAD   ERROR
NAME                  UP  ERROR    UNINITIALIZED  UNINITIALIZED  VERSION  NAME     VERSION  DEPENDENCY  ERROR    ERROR  INFO
cisco-ios-cli-6.51    X   -        -              -              -        -        -        -           -        -      -
cisco-iosxr-cli-7.24  X   -        -              -              -        -        -        -           -        -      -
my_test               -   -        -              X              -        -        -        -           -        -      -
Checking the python log:
user@{my-mac} logs % cat ncs-python-vm.log
<INFO> 15-Apr-2020::09:41:30.833 {my-mac} ncs[8715]: Started PyVM: <<"my_test">> , Port=#Port<0.11339> , OSpid="8807"
<INFO> 15-Apr-2020::09:41:31.089 {my-mac} ncs[8715]: my_test :: Starting python3 -u /Users/user/tail-f/./nso-5.3.1.1/src/ncs/pyapi/ncs_pyvm/startup.py -l info -f ./logs/ncs-python-vm -i my_test
<INFO> 15-Apr-2020::09:41:31.464 {my-mac} ncs[8715]: my_test :: Traceback (most recent call last):
  File "/Users/user/tail-f/./nso-5.3.1.1/src/ncs/pyapi/ncs_pyvm/startup.py", line 6, in <module>
<INFO> 15-Apr-2020::09:41:31.464 {my-mac} ncs[8715]: my_test ::     import ncsctlsock
  File "/Users/user/tail-f/nso-5.3.1.1/src/ncs/pyapi/ncs_pyvm/ncsctlsock.py", line 5, in <module>
<INFO> 15-Apr-2020::09:41:31.464 {my-mac} ncs[8715]: my_test ::     import _ncs
  File "/Users/user/tail-f/nso-5.3.1.1/src/ncs/pyapi/_ncs/__init__.py", line 19, in <module>
<INFO> 15-Apr-2020::09:41:31.464 {my-mac} ncs[8715]: my_test ::     from ._ncs_py3 import cdb
ImportError: dlopen(/Users/user/tail-f/nso-5.3.1.1/src/ncs/pyapi/_ncs/_ncs_py3.abi3.so, 2): Symbol not found: _PyIOBase_Type
  Referenced from: /Users/user/tail-f/nso-5.3.1.1/src/ncs/pyapi/_ncs/_ncs_py3.abi3.so
  Expected in: flat namespace
 in /Users/user/tail-f/nso-5.3.1.1/src/ncs/pyapi/_ncs/_ncs_py3.abi3.so
<INFO> 15-Apr-2020::09:41:31.468 {my-mac} ncs[8715]: Got EXIT on Port= #Port<0.11339>
<INFO> 15-Apr-2020::09:41:31.475 {my-mac} ncs[8715]: Restarted PyVM: <<"my_test">> , Port=#Port<0.12897> , OSpid="8816"
<INFO> 15-Apr-2020::09:41:31.482 {my-mac} ncs[8715]: my_test :: Starting python3 -u /Users/user/tail-f/./nso-5.3.1.1/src/ncs/pyapi/ncs_pyvm/startup.py -l info -f ./logs/ncs-python-vm -i my_test
<INFO> 15-Apr-2020::09:41:31.534 {my-mac} ncs[8715]: my_test :: Traceback (most recent call last):
<INFO> 15-Apr-2020::09:41:31.534 {my-mac} ncs[8715]: my_test ::     import ncsctlsock
<INFO> 15-Apr-2020::09:41:31.534 {my-mac} ncs[8715]: my_test ::     import _ncs
<INFO> 15-Apr-2020::09:41:31.534 {my-mac} ncs[8715]: my_test ::     from ._ncs_py3 import cdb
<INFO> 15-Apr-2020::09:41:31.538 {my-mac} ncs[8715]: Got EXIT on Port= #Port<0.12897>
What does "Symbol not found: _PyIOBase_Type" mean? How can I fix it?
I have had several versions of NSO running on my Mac(s), but never seen this before.
I recently got a new Mac, and to begin with NSO 5.2.1 was running fine on that new Mac. But now I have this issue with 5.2.1 and 5.3.1.1. Have I messed up the Python installation on my Mac or the $PATH or....?
Python seems good:
# ncs-run % python --version
Python 3.7.3
# ncs-run % python2 --version
Python 2.7.16
# ncs-run % python3 --version
Python 3.7.3
I have Java installed, I have paramiko..What is missing?
perander
This is an issue with the NSO Python API since Python 3 removed PyObject PyIOBase_Type.
It is fixed in NSO-5.3.4.
6 Replies 6
asandore
Did you ever solve this problem? I'm facing the same issue
I have python2 and python3 installed on my mac, output:
$ python --version
Python 2.7.17
$ python2 --version
Python 2.7.17
$ python3 --version
Python 3.7.3
gschudel
on the Mac, install "homebrew" and use "brew install python" (which does both python2 and python3)...
and then try again...
(Mac seems to put (natively) python in non-standard locations... Brew seems to resolve this... I ran into this on Catalina a week ago - the above was _all_ i needed to do...)
Even doing brew install python didn't solve the issue.
On package reload, I still see
I am getting this specific issue with NFVO package?
any further suggestions?
I had to fully uninstall python3 and reinstall
uwankhed
I had this error in my local nso install on mac after I upgraded to Monterey. None of the above posted options worked for me. I had to reinstall NSO to make it work.
perander
