NSO Tailf-hcc 5.x documentation
brett.harding
Please can someone advise me where I can find the configuration guide for tailf-hcc 5.x, more specifically around configuring L3 High availability using goBGP
vleijon
The documentation should be included in the package, I checked ncs-5.5-tailf-hcc-project-5.0.0.tar.gz and it contains doc-tailf_hcc.pdf, that is hopefully what you are looking for.
Hi @vleijon
Thank you. I did see that document however it appears to be lacking a lot of information when compared to previous versions of the same document. I am looking for some deployment guides / examples using GoBGP and would also like to know which protocols / ports are used for CDB replication and monitoring HA state between masters and slaves.
I was not aware of that. You may have to reach out to the support for that information unless someone else here knows.
