NSO upgrading
elpriel
I'm trying to upgrade my NSO to version 6.0 and getting the following error
Starting ncs: Bad configuration: /etc/ncs/ncs.conf:0: /var/opt/ncs/state/packages-in-use/1/cisco-nx-cli-5.22/load-dir/tailf-ned-secrets.fxs: Must be recompiled!
Daemon died status=21
any idea how to solve this?
Elad
ramkraja
This error means that the NED you are trying to load is not compiled for NSO-6.0.
Did you get a version of this NED specific to NSO-6.0? Otherwise, you need to recompile it with NSO-6.0 (not only this NED, but all your packages need to be recompiled with NSO-6.0).
/Ram
I see,
Thanks I will test it out
