problem installing mobility function pack to NSO
momeirz
trying to install the mob function pack mob-fp-3.4.0-21.27.2 to NSO version 5.7.6.1 but i'm getting the below error when packages are reloaded:
reload-result {
package nfv-vim
result false
info INSTANTIATE_COMPONENT[nfv-vim:Netconf notification subscriber[FAIL in ImageMonitor init()]]
admin@ncs# *** ALARM package-load-failure: INSTANTIATE_COMPONENT[nfv-vim:Netconf notification subscriber[FAIL in ImageMonitor init()]]
the package is loaded successfully just when i redeploy the nfv-vim package alone ...
tried to add in /etc/ncs/ncs.conf below configuration from mobility NSO setup document but without any use
<ncs-config>
<event-streams>
<notifications>
<stream>
<name>nfv-events</name>
<description>Generic netconf notification stream for NFV events</description>
<replay-support>true</replay-support>
<builtin-replay-store>
<enabled>true</enabled>
<dir>${NCS_RUN_DIR}/state</dir>
<max-size>S10M</max-size>
<max-files>50</max-files>
</builtin-replay-store>
</stream>
</event-streams>
</notifications>
</ncs-config>
I have attached error log from ncs-java-vm.log
any body can help ?
mkalyana
NSO MFP 3.4 has not been validated with newer 5.6 or newer versions of NSO. This is tracked by CDETS CSCwd29108
