NSO - Viptela unsupported
yvivekan
I'm a new bee , while trying to integrate, was able to proceed till on boarding the device to NSO.  Right now, got stuck at "sync" status with "unsupported"
NSO 4.7
nso-4.7.1-sdwan-1.3.0
nso-4.7.1-vBranch-1.5.0
devices device vmanage-1 check-sync
result unsupported
Any clue / directions  .. kindly help
vleijon
The message means that check-sync is not supported for that device type. Typically because it would be unreasonably expensive and/or wouldn't tell you much of interest. So this doesn't indicate a problem of any kind by itself.
vleijon
so if i do the config changes  in NSO and push, would it reflect in the vManage?
Yes, im able to create config in NSO and could see it in the Device ...
so , the check-sync is not supported ... but functionality worked.
question : if so, how do it validate all my devices are "insync" .. this is the one of the necessity of NSO ? .... so it means, the device team has to enable this feature in their product ?
