NSO Web UI Container with leafref leaf
neetimit
Hello!!
I am using NSO 5.2.2, I have a service model where I have a container (presence true). In that container, there is a leaf which is leafref.
Snippet of service model given :
service model snippet:
choice type {
      case odn {
        container odn {
          presence true;
          leaf route-policy {
            tailf:info "Route policy definition";
            description "Route policy definition";
            type leafref {
              path "/cisco-flat-L2vpn-fp:l2vpn-route-policy/cisco-flat-L2vpn-fp:name";
            mandatory true;
          leaf direction {
              tailf:info "Route policy direction";
              description "Route policy direction";
              type enumeration {
                  enum in;
                  enum out;
              default in;
      case preferred-path {
        uses sr-te-pref-path-grp;
On NSO web UI, I create a service with odn and a valid route-policy and commit. Now, I want to remove the route-policy (basically the odn container). Web UI doesn't let me do that. Same thing from CLI can be done like:
admin@ncs(config)# no cisco-flat-L2vpn-fp:flat-L2vpn evpn-vpws-1 flat-L2vpn-evpn-vpws local-site sr-te odn
admin@ncs(config)# commit dry-run
cli {
    local-node {
        data  flat-L2vpn evpn-vpws-1 {
                  flat-L2vpn-evpn-vpws {
                      local-site {
                          sr-te {
             -                odn {
             -                    route-policy evpn_policy1;
Is there something I can do in this model to overcome this issue since customer will be using web UI for service configuration.
Is this a known issue with web UI? Do we have the fix for this in later versions or planned?
Neetika
neetimit
I figured out Web UI has an option on top right corner to handle deletion of containers
neetimit
