NSO webui questions
Thomas Tribolet
I'm making some tests on demo version of nso ( 4.7 ).
I have 2 questions relating NSO webui :
A) Is it possible to print the tailf:info or description value of yang in the webui ?
B) When we have a list with lot of element, we can only search on the first +-20 items listed on page. Is there a way to list more items or to search through the whole list  ?
Thanks for your help
richsun
In Application hub: select Legacy/Webui Prime. The previous version of UI shows both tailf:info and all entries of a list in one page.
dapryor
Did you ever figure out a solution for the new UI?
Sadly, I didn't found what I wanted.
You can active the "..." ( more node option ) option on the up right screen.
Then you have the "!" icon on each block. If you click on it, you have more information with the description.
We hoped to have this functionality with the 5.1.1 version but nothing has changed for this.
Bg,
