opaque properties for Python API
Gastonper
Level 2
Level 2
Hi, I have a case where I need a persistante FASTMAP properties.
NSO development doc (pag 252), says that there is an argument ("opaque") in the JAVA API service for this.
I wonder if this propertie exist also in the magic python API, or I must use a java-template service type.
3 Accepted Solutions
vleijon
It exists in python it is the “proplist” argument in the python create code.
Thanks!
Is there any example of how to use it?
Sorry, could not quickly find a good example. But it is a list of tuples, you just need to modify the list and return it from the create function and it will be given back to you on next deploy.
vleijon
Thanks!
