packages-reload error: missing module
billirubin05120
I have just recently started working with Cisco NSO and I have been following these tutorials: "Understand how to use Cisco NSO to build a service for a specific configuration" (https://www.youtube.com/watch?v=AGVChkovQ7s) and "Cisco NSO, add Python logic to a service" (https://www.youtube.com/watch?v=4hCLAYbxjwE&feature=emb_title) .
Everything is working alright until minute 10:05 in the second video "Cisco NSO, add Python logic to a service". I successfully created the new package called "access" by using the ncs-make-package --service-skeleton python-and-template access command and altered the YANG and XML files as instructed in the video. After altering the main.py file and importing the resource_manager module, however, I received a problem when running the packages-reload command. It states that there is an error: ModuleNotFoundError: No module named resource_manager.
I have checked into my Cisco NSO configuration and saw that this resource_manager module is installed and it is located in the directory example.ncs/service-provider/virtual-mpls-vpn/packages/resource-manager/.
It is not clear to me why this particular error is being generated. Could someone explain to me why I am receiving this error and how I can fix it? Below I have attached two pictures, one from my main.py where it is shown how the resource_manager module is imported, and one from the generated error.
vleijon
Well, the simplest thing to check is this: You need the resource-manager to be in the packages directory that you are working in, if it isn’t copy it there.
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
