Path in nacm rule
Ben Kelly
I'm trying to create a nacm rule for a particular service I've created. The service looks like this:
services fw_acl_03 bk-app-1
device [ svlngen4-fab6-dmzdc-02-fw1 ]
dmz_hosts 10.1.1.1
allowed_dest_entry 192.168.1.0/24
protocol       tcp
  dst_port_start 22
  dst_port_end   22
The rule and path that I have specified is:
nacm rule-list bk-app-1
group [ app-group-1 ]
rule bk-app-1_allow
  path              /services/fw_acl_03/bk-app-1
  access-operations create,read,update,delete
  action            permit
However, it's not matching. Is there an error in the path?
yfherzog
Are you looking into blocking access to the specific instance of that service, rather than all instances?
If so, I think that the value to the path leaf in your rule should be a little different.
If you log into ncs_cli and display the xpath to your service instance, you'd see something like this:
show run services fw_acl_03 bk-app-1 | display xpath
/services/fw_acl_03[name='bk-app-1']
Note that instead of 'name' you'll see that actual name of the key leaf (which might be 'name', or something different).
You need to have that path in your rule instead of the one you have at the moment.
Yftach
yfherzog
Yftach
Ben Kelly
Yep, that's working now. Thanks Yftach!
