Problem in NED make on NSO 4.5
mowahba
I just installed NSO 4.5 and ran into this error when I was trying to make the NEDs for IOS, XR & JUNOS
[root@localhost neds]# cd cisco-ios
[root@localhost cisco-ios]# cd src
[root@localhost src]# ll
total 16
drwxr-xr-x. 4 root root 4096 Nov 30 19:01 java
-rw-r--r--. 1 root root 2175 Nov 30 19:01 Makefile
drwxr-xr-x. 3 root root 4096 Nov 30 19:01 ncsc-out
drwxr-xr-x. 2 root root 4096 Nov 30 19:01 yang
[root@localhost src]# make
Makefile:17: /src/ncs/build/include.ncs.mk: No such file or directory
/bin/sh: - : invalid option
Usage: /bin/sh [GNU long option] [option] ...
  /bin/sh [GNU long option] [option] script-file ...
GNU long options:
  --debug
  --debugger
  --dump-po-strings
  --dump-strings
  --help
  --init-file
  --login
  --noediting
  --noprofile
  --norc
  --posix
  --protected
  --rcfile
  --rpm-requires
  --restricted
  --verbose
  --version
Shell options:
  -irsD or -c command or -O shopt_option (invocation only)
  -abefhkmnptuvxBCHP or -o option
make: *** No rule to make target `/src/ncs/build/include.ncs.mk'.  Stop.
any guidance ?
Jan Lindblad
You forgot to source the ncsrc file of the NSO version you intend to use.
Say I want to use NSO 4.5.1 and have it installed in ~/nso/4.5.1, I'd run this command in a bash-family shell:
. ~/nso/4.5.1/ncsrc
Then retry your build.
mowahba
It works now , thanks Jan !
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
