Problem retrieving operational data via NETCONF
Giulios
I'm having a problem with NSO when trying to retrieve operational data from a NETCONF device. If I try to use the web interface I see in the up right corner this message "Due to the size of this configuration model, subfolders are not included".
I think it might be a problem of how deep my YANG model is, since the only data I can not make NSO show to me is the one corresponding to the "deeper" leaves in the model. I could not find in the documentation an explanation to that or if it is possible to make NSO use my model one layer further.
When dealing with configuration data this is not an issue and it is possible to set all the data. It is probably not a problem of the NETCONF server, since I could retrieve correctly all the operational data when using ncclient (netconf-console).
Thanks in advance,
Giulio
0 Replies 0
