Providing CLI "help" Message
kecorbin
Is there a substatement for setting the help message provided for a node when using the CLI?  description and reference seem to be the obvious choices, but they don't seem to populate.
admin@ncs(config)# vpc-distribution EAST ?
Possible completions:
  peer-link
  aggregate-prefix
  check-sync           Check if device config is according to the service
    leaf aggregate-prefix {
      description
        "This pool is used to pull the /24's needed for VLANs, this prefix is also
        advertised northbound of the distribution block";
      type inet:ipv4-prefix;
      mandatory true;
    container peer-link {
      reference "Configure Peer link interfaces/properties";
      list interface {
        key interface;
        leaf interface {
          type string;
yfherzog
You can use tailf:info for that.
You'll need to import tailf-common before you use it.
  import tailf-common {
    prefix tailf;
      leaf customer-name  {
        tailf:info "Put your message here";
        mandatory true;
        type string;
yfherzog
    prefix tailf;
        mandatory true;
        type string;
Exactly what I needed, thank you!
