pyang Default path for yang files
DTtb
If I try to validate with pyang my YANG-model with imported submodules, I need to specify the path to the external submodules.
For the built-in yang-models, like ietf-inet-types, I don't need to specify the path.
But the man-page of pyang describes following:
See http://www.yang-central.org/twiki/pub/Main/YangTools/pyang.1.html
The following directories are always added to the search path:
  1. current directory
  2. $YANG_MODPATH
  3. $HOME/yang/modules
  4. $YANG_INSTALL/yang/modules OR if $YANG_INSTALL is unset <the default installation directory>/yang/modules (on Unix systems: /usr/share/yang/modules)
module my-module {
namespace "http://test.com/my-module";
prefix mymodule;
import ietf-inet-types {
prefix inet;
import tailf-common {
prefix tailf;
import tailf-ncs {
prefix ncs;
import private-module {
prefix private;
//yang code ...
[root@c945565b350c yang]# pyang my-module.yang
my-module.yang:15: error: module "private-module" not found in search path
So, the default path for the built-in yang modules is /ncs/src/yang/.
Does NSO exposed the path to the built-in yang modules to pyang?
gmuloche
It depends what pyang you are using. If you type which pyang and it returns you some bin in $NCS_DIR/bin/pyang then this is a script which wraps pyang contained inside NSO and will set/add to the following env variables (snippet):
13 pyang=$ncsdir/lib/pyang/bin/pyang
14
15 if [ "x${PYTHONPATH}" != "x" ]; then
16 PYTHONPATH=$ncsdir/lib/pyang:$PYTHONPATH
17 else
18 PYTHONPATH=$ncsdir/lib/pyang
19 fi
20 if [ "x${YANG_MODPATH}" != "x" ]; then
21 YANG_MODPATH=$ncsdir/src/ncs/yang:$YANG_MODPATH
22 else
23 YANG_MODPATH=$ncsdir/src/ncs/yang
24 fi
25 export PYTHONPATH YANG_MODPATH
26
27 exec $pyang "$@"
So it is setting the YANG_MODPATH variable to a folder where the built-in module resides and according to the man page they will be used. So the answer is "yes, the wrapper script `pyang` in NSO is exposing the built-in modules"
Guillaume
gmuloche
14
17 else
19 fi
22 else
24 fi
26
27 exec $pyang "$@"
Guillaume
