Python thread closing and JVM terminated
spudukko
Recently i saw this issue where the python VM crashed while execution lux test. This is random and i am unable to find the reason. If i execute the lux again , it passes. There was error in  any python-nfvis logs .  To add more data it happens when ncs is started.
2017-11-02 21:37:10 - tailf-etsi-rel2-nfvo-nfvis-staged-delete - INFO - Starting...
2017-11-02 21:37:10 - tailf-etsi-rel2-nfvo-nfvis-staged-delete - INFO - Started
2017-11-02 21:41:14 - tailf-etsi-rel2-nfvo-nfvis-staged-delete - ERROR - ConfD closed connection
2017-11-02 21:41:14 - tailf-etsi-rel2-nfvo-nfvis-staged-delete - ERROR - Traceback (most recent call last):
  File "/auto/nso/tools/nso/4.4.4/src/ncs/pyapi/ncs_pyvm/ncsthreads.py", line 172, in run
    self.main._run()
  File "/auto/nso/tools/nso/4.4.4/src/ncs/pyapi/ncs/application.py", line 218, in _run
    with maapi.Maapi(load_schemas=True):
  File "/auto/nso/tools/nso/4.4.4/src/ncs/pyapi/ncs/maapi.py", line 181, in __init__
    self.load_schemas()
  File "/auto/nso/tools/nso/4.4.4/src/ncs/pyapi/ncs/maapi.py", line 396, in load_schemas
    _tm.maapi.load_schemas(self.msock)
EOF: ConfD closed connection
2017-11-02 21:41:17 - tailf-etsi-rel2-nfvo-nfvis-staged-delete - INFO - Exiting...
2017-11-02 21:41:17 - root - ERROR - Traceback (most recent call last):
  File "/auto/nso/tools/nso/4.4.4/src/ncs/pyapi/ncs_pyvm/ncsthreads.py", line 68, in _finish
    x()
  File "/auto/nso/tools/nso/4.4.4/src/ncs/pyapi/ncs/application.py", line 241, in _finish
    self.wait.release()
AttributeError: 'NoneType' object has no attribute 'release'
2017-11-02 21:41:17 - tailf-etsi-rel2-nfvo-nfvis-staged-delete - INFO - Exited
2017-11-02 21:41:17 - tailf-etsi-rel2-nfvo-nfvis-staged-delete - INFO - Goodbye cruel world...
Jan Lindblad
JVM and PythonVM dying when NSO starts.. Sounds a bit like you might be running out of memory. What packages do you have in your NSO environment, and how much free memory before you start? Did you run any command to raise the JVM memory limit?
Jan Lindblad
