Python upgrade script with attach_init() (phase0)
Olof1
Community Member
I'm trying to write a package upgrade script. The one in https://community.cisco.com/t5/nso-developer-hub-documents/nso-service-upgrade-with-python/ta-p/3640379 seems to work fine but I would like to avoid keeping the old YANG leafs.
In Java there's a attachInit() method to do this. I can see a attach_init() in the Python API but I cannot get it to work. Any working examples out there?
I finally managed to write an update script in Python. We had to start ncs in --start-phase0 and use start_phase(), init_upgrade(), perform_upgrade() and commit_upgrade().
In-service upgrade would be much nicer though. I will ask our Cisco rep for a feature request.
Thanks!
Jan Lindblad
The attach_init() needs to be called in "phase 0" to work, which isn't when you are calling it. Unfortunately there is currently (NSO 4.7) no good way to get an upgrade callback at the right time in python, only in java. If you wrote a java upgrade snippet that started a python VM that connected to NSO, and did the work, that might work. Another, possibly better, approach would be to write a feature request for python upgrade callback support.
Thanks!
