Question about applying template in cb_create function
previousqna
Level 8
Level 8
All ,
I have the need to apply a template within cb_create but then adjust some values of the service object before returning from cb_create.
i.e.
template = ncs.template.Template(service)
template.apply('xyz-template', vars)
service.status = somefunction()
It appears the service.status leaf doesn’t get assigned the value.
I suspect the template.apply() is closing out a transaction so any later attempts of modifying the service object are ignored?
I could reopen a new transaction after template.apply() but that seems messy.
Just curious if anyone knows what is happening in the background.
previousqna
Level 8
Level 8
A service’s create-cb should not be touching the service configs. Badness.
Also, note, every time service’s create-cb is called, it should recreate the device mappings.
Looks like the Plan component can help?
