Question about NSO Alarm Implementation
previousqna
Level 5
Level 5
Hi NSO experts.
I got a question from my customer about NSO Alarm implementation.
NSO Northbound APIs Chapter 5. NSO Alarms says following alarm type are supported.
alarm-type
ncs-cluster-alarm
cluster-subscriber-failure
ncs-dev-manager-alarm
ned-live-tree-connection-failure
dev-manager-internal-error
final-commit-error
commit-through-queue-blocked
bad-user-input
abort-error
revision-error
missing-transaction-id
configuration-error
commit-through-queue-failed
connection-failure
out-of-sync
ncs-snmp-notification-receiver-alarm
receiver-configuration-error
ncs-package-alarm
Also Chapter 4. The NSO SNMP Agent describes OID
tfAlarmIndeterminate notification 1.3.6.1.4.1.24961.2.103.2.0.1
tfAlarmWarning notification 1.3.6.1.4.1.24961.2.103.2.0.2
tfAlarmMinor notification 1.3.6.1.4.1.24961.2.103.2.0.3
tfAlarmMajor notification 1.3.6.1.4.1.24961.2.103.2.0.4
tfAlarmCritical notification 1.3.6.1.4.1.24961.2.103.2.0.5
tfAlarmClear notification 1.3.6.1.4.1.24961.2.103.2.0.6
Is there a list which OID is used for each alarm type?
previousqna
Level 5
Level 5
I haven’t looked into this topic for a while, below is what I can find in my notes.
NSO defines 6 different “types” of notifications. This mainly to cater for legacy Alarm Manager Applications that have a limitation of only being able to de-multiplex the alarms on the basis of severity. This is more so that NSO can interoperate with those legacy applications. These six notifications are defined in the MIB:
tfAlarmNotifs NOTIFICATION-GROUP
    NOTIFICATIONS {
tfAlarmIndeterminate,
tfAlarmWarning,
tfAlarmMinor,
tfAlarmMajor,
tfAlarmCritical,
tfAlarmClear
For the new breed of Alarm Manager Application there is no such restriction. Hence, inside the notification itself we have fields that should be used to uniquely identify the alarm-type (including alarms listed in the email below and/or custom alarms defined by the customer). These fields are:
    1. Device
    1. Managed-Object
    1. Alarm-Type: using X733 conventions this is a tuple (event-type, probably-cause)
    1. Specific-Problem ß Use this to define as many different Alarm types as required.
Using the “Specific-Problem” field, customer can define as many alarm types as they want over and beyond what is available via the X733 Alarm-Types. The Alarm Manager module in NSO is built to allow for the mentioned flexibility and extensibility. In the Alarm Manager being used by the customer, they just need to de-mux using the combination of the 4 key fields mentioned above:
tfAlarmIndeterminate NOTIFICATION-TYPE
    OBJECTS {
tfAlarmType,
tfAlarmDevice,
tfAlarmObject,
tfAlarmObjectOID,
tfAlarmObjectStr,
tfAlarmSpecificProblem,
tfAlarmEventType,
tfAlarmProbableCause,
tfAlarmTime,
tfAlarmText
Thank you for answering my question.
Can I ask you one more specific question?
NSO Northbound APIs doc “Chapter 4. The NSO SNMP Agent” says there are several OIDs for Alarm.
Is it possible to predict which OIDs are used for each alarm type?
For example, which OID is used when out-of-sync occurs?
Is there a kind of list to show it?
Thanks to bother you again and I really appreciate your help.
When the alarm is submitted:
submitAlarm(...,PerceivedSeverity severity)
the severity is passed on at submission time.
So, for alarms defined and submitted by a service, the service-designer has to document/communicate this piece of info to the stakeholders.
With regards to some of the alarms listed below that we have pre-defined in NSO, one could trigger them and then check the alarm-list to see the severity that they were submitted with.
I’ve done a quick search of the code-base (pardon my knowledge of erlang) and have cut-pasted the definitions for reference (please see attached file – alarm-def.txt). I’m not sure if this is documented anywhere and whether these assignments can change over time. Best to consult with engineering on this.
Thank you very much.
The file you attached includes the combination of “alarm type” and “sevirity”.
So I can get which OID is used for each alarm type.
I cannot thank you enough.
