re-deploy dry-run using Java
neetimit
Hello!
If anyone has the code snippet for re-deploy dry-run in java, can you please share?
Neetika
neetimit
ConfXMLParam[] params1 =
    new ConfXMLParam[] {
        new ConfXMLParamStart(cs, Ncs._dry_run_),
        new ConfXMLParamValue(cs.hash(), Ncs._outformat, new ConfEnumeration(Ncs._outformat_native)),
        new ConfXMLParamStop(cs, Ncs._dry_run_)};
ConfXMLParam[] diff =  maapi.requestAction(params1, path + "{%s %s %s}/re-deploy", <key>);
for (ConfXMLParam p : diff) {
Alexander Stevenson
Hello Neetika,
I would definitely take a look at the NSO Developer space on GitHub
Hope this helps!
neetimit
subhapad
If anyone has the code snippet for re-deploy dry-run in python, can you please share?
Thanks in Advance!
